LED replacement bulb issue...
Old Oct 18, 2006 | 11:41 PM
04procompLARIAT's Avatar
I just got some Luxeon LED bulbs to put into my stock taillights. I also purchased the 6ohm load resistors. I also have the LED turn signals in the front with the 6ohm resistors installed already. I installed the bulb in the rear and with the resistor installed the blinkers wouldnt blink, it was just a dull light. Whats the deal? Are the dual 6 ohm resistors too much? What should I use?
Old Oct 19, 2006 | 12:06 AM
ryanbeal's Avatar
Have you tried it without the resistor?
Old Oct 19, 2006 | 12:53 AM
styxnpicks's Avatar
what's the led's forwad voltage. this is simple electical math. we already know we need to bring it down from 14.4v if you got a link to the LED that would help too
Old Oct 19, 2006 | 02:51 AM
Oh golly I really suck at math! Here is the info page for the bulbs I purchased...http://superbrightleds.com/specs/315x-xLX3.htm And when I do not have the resistors on they hyper blink.
Old Oct 19, 2006 | 05:01 AM
styxnpicks's Avatar
oh hahahah I know what your doin wrong. your running the resistor in series. its designed to be run parallel with the bulb.
Old Oct 19, 2006 | 02:49 PM
ok hahhaahaha....please explain? I hooked it up like the instructions told me to.
Old Oct 19, 2006 | 09:54 PM
Adam06FX4's Avatar
Registered User
i belive he meens from one wire to the other instead of inline of one wire
Old Oct 20, 2006 | 12:13 AM
cobra909's Avatar
Guys, please enlighten this poor ol country boy, but why do you need a resistor at all? The specs indicate that the operating range for these lamps are from 10 to 14 vdc. If you go back to the manufacturers home page, it also tells you that these are supposed to be "drop in replacements" and have "built in" resistors. Am I missing something? You will probably also have to replace the original electronic flasher with a "Heavy Duty" flasher. Good Luck.
Old Oct 20, 2006 | 02:48 AM
Country boy? Hmm....San Diego is country? uh huh...I dunno what to say...I am not stupid when it comes to electronic stuff on my truck. Either I am having a major brain fart or something isnt right. The previous post's are not helping at all.
