~Stains~
Old Oct 18, 2006 | 02:02 AM
Dian's Avatar
~Stains~
Have any of you guys with cloth interiors had any tough stains that you were able to remove from the fabric? If so, what did you use?
Thanks in advance!
Old Oct 18, 2006 | 08:49 AM
05supercrew's Avatar
This has been beat to death, do a search and you will have days of reading. One person said steam cleaning worked, but what I did was scotch guard and that seemed to help. I have 2 small kids and a wife who for some reason needs to feed the kids in my truck when we go out. So she spills everything and I havent had a problem yet. Good luck.
Old Oct 18, 2006 | 09:40 AM
allrsdup's Avatar
my drivers seat was a little dirty i used scrubin bubbles it was under the sink used for bathroom tiles usually worked great seat was like new when i was done.
Old Oct 18, 2006 | 11:02 AM
mkinttrim's Avatar
A little vinegar,a little baking soda mixed with good ole H2O! Will work great on most things except grease.
Old Oct 18, 2006 | 11:35 AM
silverbullet5.4's Avatar
Nothing will get the water stains out, these seats stain way too easily. The only solution: Get leather seats or buy covers, because you will drive youself crazy and probably make the stains worse.
Ford actually designed a material that can be stained by pure water, its amazing.
Old Oct 18, 2006 | 11:46 AM
Z-MAN_FX4's Avatar
I use automotive carpet cleaner with the brush that it comes with and then hit it with the shop vac. Works pretty good IMO
Old Oct 18, 2006 | 12:58 PM
allrsdup's Avatar
not just ford my dads 05 dodge dakota is even worse he hates the material on his seats they are water staind like u would not believe the scrubbin bubbles worked on my water stains on my ford.
Old Oct 18, 2006 | 05:18 PM
evo's Avatar
evo
I've used Simply Green diluted in water with good luck.
Old Oct 19, 2006 | 12:30 PM
rzims's Avatar
Nothing works - I tried the Oxy stuff and it doesn't work, the car carpet stuff with the brush, no joy....I haven't found anything yet.
Old Oct 19, 2006 | 04:26 PM
ian51279's Avatar
I've used the Simple Green it works good. The last product I used was Hoover Spot & Stain Cleaner, picked it up at Lowe's. These 2 products have removed everything. Grease, water stains, ink, etc. It may take 2-3 cleanings per spot to remove it but it will come out. Don't use to much cleaner in one spot, you will wind up with a bigger water spot in that area. Once your seats are clean, Scotchguard them. It works. I finally got my seats all cleaned up and Scotchguarded them back around July 4. Guess what? No more stain on my seats.
