Puff or No Puff
Old Oct 16, 2006 | 03:56 PM
cobra909's Avatar
Question Puff or No Puff
Hey guys and gals. Trying to get everyone to respond to see if this is a problem that Ford needs to be aware of. The question is; Do you notice a puff of white smoke from your exhaust when starting your cold 5.4. A few of us in another thread have noticed this; I just had 2 injectors fail and were changed out (luckily, under warranty).
When did you first notice puff? Day I brought truck home.
Any injectors change out? 2
What mileage did all occur? Injectors failed at 29900. Two weeks ago.
Did you notice any times where engine was hard to start or missing, then would clear up? A couple of times in the last 6 months.
Thanks for everyone's input
Old Oct 16, 2006 | 04:23 PM
sandyf150's Avatar
Mine is an 05 with almost 29000 miles and no problems whatsoever
Old Oct 16, 2006 | 04:26 PM
sysman_rick's Avatar
'05 Supercrew 5.4 l,18000 miles. No problems.
Old Oct 16, 2006 | 04:31 PM
FX4_Guy's Avatar
No problems @ 20,000 miles.
Old Oct 16, 2006 | 04:36 PM
torturekilla's Avatar
06 26000miles nothing.....
Old Oct 16, 2006 | 04:58 PM
NASSTY's Avatar
A little white smoke is normal on cold starts.There is usually condensation(moisture) dripping out of the tail pipe(s) until the engine and exhaust pipes heat up.
Old Oct 16, 2006 | 08:26 PM
allrsdup's Avatar
every car has white smoke when it is cold out untill it warms up it is condensation in the exhaust
Old Oct 16, 2006 | 09:29 PM
Josiah's Avatar
That is normal from what I know. However I've seen white smoke @ WOT on the beach. Might have been the water smoking from the tailpipes.
Old Oct 16, 2006 | 09:42 PM
ryanbeal's Avatar
Question
44,000 no problems with injector failure. What causes an injector to fail? Design? Production problem? Internal failure? Contamination? Any thoughts?
Old Oct 16, 2006 | 10:35 PM
cobra909's Avatar
Originally Posted by allrsdup
every car has white smoke when it is cold out untill it warms up it is condensation in the exhaust :
Well guys, like I said, ever since they replaced the injectors...No Smoke; Wife's '04 Sequoia, No Smoke, etc, etc.. Not down here in SW Louisiana. Yes, it'll happen when the cool season gets here, but not until.
Old Oct 17, 2006 | 12:35 AM
allrsdup's Avatar
mine always does it when it is cool out avery car i ever owned has done it. more so on the 4 fords i have owned however.
Old Oct 17, 2006 | 07:24 AM
evtide's Avatar
'05 5.4, 33K miles. One puff that I noticed last week, def. not moisture as it STUNK. I get the pinging, have noticed 2 or 3 mis-starts in the past 2 months. Dealer says not to worry, normal, etc. Didn't even put it on the diagnostic machine and refused to re-flash. Grrrr.
Old Oct 17, 2006 | 07:36 AM
FX4ME2's Avatar
I have roughly 9000 miles on my 05. I'm going to stop buy the dealer today and see what they say.
Old Oct 17, 2006 | 08:20 AM
MGDfan's Avatar
Hi.
I don't smoke
Cheers
Bubba
Old Oct 18, 2006 | 12:46 AM
cobra909's Avatar
(Stunk) That's the kicker I forgot to mention. Even if smoke is normal as in condensation, it should have very little smell to it. If it's an injector problem, you will smell the fuel. I'd go back to your dealer and tell him BS, that it ain't right. Good luck.
