Front suspension noise months later after Leveling...
Old Oct 2, 2006 | 07:57 PM
giorgioF150's Avatar
Hi
What's the deal here anyway!!! am I supose to have and pay for this suspension trouble because I want spacers and cooler rims and tires?
What did I did wrong?
I don't know nothing about suspensions and stuff.., I don't even know exactly what the "Suspension" is.
So, I liked very much how my truck looks all leveled..
but now, after like 5-6 months, with every shake I get metalic "cluncks" and "clancks"...
I went to a Brake and suspension workshop and they told me that for the time truck has since I purchase it(10months) it shouldn't give those noises... but then I told him that those tires and rims are bigger and it has some spacers... then he told me that that was the reason.
They have to replace joints(???) and stuff.. (like 175.00us).. he also told me that I could take it to the Dealershipp and see what they say.
I supose my dealer is going to tell me the warranty is void, etc. but I'll check
Any ideas?
Thank you
Giorgio
Old Oct 2, 2006 | 08:15 PM
BalogUK's Avatar
check the three bolts on the top of each strut assembly (right above the leveling kit) with a torque wrench- they could be coming loose- so crank them all down, then see if the noise persists... J
Old Oct 2, 2006 | 08:27 PM
powerage's Avatar
Check your upper Ball joints. That's exactly what happened to mine
Old Oct 2, 2006 | 08:51 PM
TonkaTruck33's Avatar
if the stealership tell you they cant fix it, go to McAllen to a ford dealership see if they can help you out. since ur from Reynosa Tamp mexico right..? my dad use to have a 2005 ford f150 he bought in Matamoros tamp. and he took it to the dealership here in brownsville texas to get new hub actuators at no cost.. so.. maybe they will help you out.
Old Oct 2, 2006 | 09:11 PM
quackrstackr's Avatar
Good luck but I would be surprised if you get a dealership to fix a problem that was probably caused by an aftermarket part that changed the suspension geometry.
Old Oct 2, 2006 | 10:48 PM
ThumperMX113's Avatar
Why don't you go back to the people who did the work? But check all of the bolts first before you start flipping out. .
Check the top three, as already stated, tie-rod ends, bottom strut bolts. I think you'll be good to go after that.
Old Oct 3, 2006 | 11:31 AM
KSpencer's Avatar
This is the most common problems with spacers. The noise is from the strut being loosened from the tower. Real easy to find...just look into the wheelwell and locate the position where the end of the coil bolts to the housing (3 bolts on top).
Old Oct 3, 2006 | 12:13 PM
When I did my spacer I didn't tighten the swaybar endlink where it connects to the lower A-arm tight enough and it made a clunk-ish sound when braking and cornering. I re-torqued it and that fixed the clunking problem. May help, may not.
Old Oct 3, 2006 | 12:19 PM
Thanks for your help...
I will go back with the work shop who installed the kit so they can check it out
Salutes
Giorgio
