Updated Pictures of Truck
Old Sep 29, 2006 | 01:36 AM
  #31
hmfic's Avatar
[QUOTE=jrbhc8]
QUOTE]
Originally Posted by ThumperMX113
No, hes saying with that much lift you need a new crossmember to get some factory CV, UCA/LCA, and tie rod angles.
No, the Skyjacker would be MUCH worse.
The Skyjacker's angles are NOT this bad. Trust me! He did say he also has Bilsteins. Is it possible that he has the adjustable ones with a 2.5" Daystar.. If not, since you had to take apart your coilover for the daystar, is it possible that your lower spring mount is flipped upside down. That would cause the harsh ride as well. That is too steep of angles for any leveling kit or 3" skyjacker.
Other than that, very sharp truck..
Old Sep 29, 2006 | 03:06 AM
  #32
jrbhc8's Avatar
The shocks are not adjustable and the dealer installed the leveling kit, so I think that the kit is in correct. Can you explain or show me what it's suppose to look like, because they may have screwed up.
Does anyone think I should get the 2.0 autospring and swap them out?
jrbhc8
Old Sep 29, 2006 | 09:36 AM
  #33
allrsdup's Avatar
jrbhc8
i would def do something because i never seen angles that bad besides the ball joints and cv joints wearing out, your suspension can not cycle corectly like that.
Old Sep 29, 2006 | 09:52 AM
  #34
jrbhc8's Avatar
I'm calling daystar today.
I'm thinking about going with the smallest autospring kit I can fit with my tires. I'm going to start a new thread asking everyones opinion and how their ride quality is.
jrbhc8
Old Sep 29, 2006 | 11:51 AM
  #35
Stragum's Avatar
good looking truck my friend!
Old Sep 29, 2006 | 01:56 PM
  #36
5.4-FX4's Avatar
so what should i do if i want to go 4" or less on a lift (to avoid the bad angles)?
Old Sep 29, 2006 | 03:52 PM
  #37
ThumperMX113's Avatar
RCD 4.5" or the Rancho 4" kits. Personally, I'd go with the RCD. Its more money but worth it.
