My exhaust set-up?
There's a shop not far from work that sells them. Internals look similar to Flowmaster as someone else said. They have one on display with the top cut out of it.
Not to trash your muffler but the one he has on display looks pretty cheaply made on the internals and he seemed to be pretty proud of the fact that most last "at least 3 years". I suppose they must be aluminized and rust out fairly quickly. He also stated that he had only had to replace one because a baffle came loose but that it had been on a drag car.
Originally Posted by UberDude
you have problems.
I have problems?
True duals are TRUE duals.. meaning the 2 pipes never meet from the headers .. and go into there own seperate mufflers..
you have a nice exhuast setup but its not true dual..
your mufler is acting like an X pipe to keep up the Back pressure.. i dont think you can True dual out these engines and not lose enough backpressure to screw up the performance..
now if you supercharge ur engine then back pressures not so good
Ever search on 'backpressure' & how it isn't the real issue on these engines (exhaust scavenging/velocity is)? Thought not.
Ever search on "openclasspro11's" true dual 2.25" SS exhaust, with an x-pipe before the mufflers, and what it performs like? Thought not.
Ever hear of proper grammar & sentence structure? Reading your post, thought not.
My only problem appears to be trying to educate someone as clueless as you ...
If stupid hurts, you must be in agony !
If ignorance is bliss, you must be estatic !
Oh, don't blow a gasket - just kidding! Seriously now, you really should take advantage of the wealth of correct info on this site. You just may learn something after all - I'll even give you the benefit of the doubt.
Cheers
Bubba
this aint english class.....
