line of fire
Old Sep 28, 2006 | 08:06 PM
Monkey-1's Avatar
Does anyone have a picture of a Line of Fire uninstalled? I got mine today and its the Bully brand and is in 3 pieces. Are they all like this or did I just get the wrong brand?
Old Sep 28, 2006 | 10:35 PM
nuclearthreat54's Avatar
Does it come with instructions? I had a shop do mine so I dont know how it comes uninstalled
Old Sep 29, 2006 | 09:05 AM
Monkey-1's Avatar
It comes with some very vague instructions. Its not that I cant figure it out. but it has some long leads and you have to plus each of the 3 pieces together to get the 60" led. The problem is that there is not a good way to hide the pigtails that plug the different strips together.
Old Sep 29, 2006 | 08:48 PM
SteveVFX4's Avatar
for what it's worth, I've been noticing these light bars recently on trucks/suv's around here, but almost everytime I see one, half the lights on the bar are burnt out. Looks tacky like that and they must not be built to last...
Old Oct 3, 2006 | 09:45 PM
GordoPanocho's Avatar
Registered User
http://www.f150store.com/Shop/ViewPr...18&SortOrder=1
Old Oct 3, 2006 | 10:01 PM
countyboy04's Avatar
Originally Posted by GordoPanocho
I like that one!
Old Oct 3, 2006 | 10:32 PM
txnole's Avatar
I could -maybe- see myself getting one. Maybe. But I think I would have to wire it only to fire when the brakes are on. I don't like the look with the parking lights that much. And the newer style with the turn signals? No.
Old Oct 3, 2006 | 10:35 PM
Yeah that sounds cool, what ever floats your Tallahassee liking boat. lol jk
Old Dec 28, 2006 | 09:06 PM
Rockpick's Avatar
Moderator &
Originally Posted by F150 Duke
How did you guys get around the not so flat metal on the right hand side of the LED line of fire? You know what I'm talking about? It's the bump in the metal on the right hand side where the line of fire LEDs go.
Also, what about that metal rod that sticks down on the right hand side. I believe you can see it blocks the view of one of the LEDs in YOMANs picture. Does that do that all the time?
Duke
PRECISELY my problem right now. Duke, I know you have a LOF in hand -- have you installed? If so, how did you dodge that plunger thingy and the 'hump' on the right side?
Old Dec 29, 2006 | 03:00 AM
F150 Duke's Avatar
I posted a response in your thread.
I don't have the guts to cut off the metal rod so it'll stay there to support the tailgate when it's down. I just notched the light bar 2 or 3 CM with my sodering iron to give the rod clearance.
The uneven metal to the right wasn't a big deal as it concaves deeper and the light bar just goes straight over it. Granted part of the 3M adhesive isn't touching there. But I warmed up the 3M adhesive before putting it on the cleaned metal and my light bar isn't moving anywhere; even when I pry on it.
Duke
Old Dec 29, 2006 | 04:22 PM
zag's Avatar
zag
Clean the metal real good and apply a piece of 3m tape to the right side of bump and then install light bar. The applied tape will take the tension off of the bar. I have had mine on going on two years and it hasn't come loose yet.
Old Dec 29, 2006 | 06:42 PM
KCSport's Avatar
That's how I wired mine, so it only works with the brake lights, turn signals and reverse. I guess someone has to be different.
Old Dec 29, 2006 | 09:30 PM
Rockpick's Avatar
Moderator &
Thanks zag... that's exactly what I believe I'm going to do... and, like Duke and others mentioned in the other LOF thread, I think I'm going to snub the running lights wire and not connect it for now...
Old Dec 30, 2006 | 02:26 PM
zag's Avatar
zag
Make sure you clean the area good with rubbing alcohol. As always ,it's the prep that counts.
Old Dec 30, 2006 | 02:51 PM
JBMX928's Avatar
Graphics Contributor
those look pretty cool
what do they cost?
and do you just plug them into the electric outlet next to the tow hitch?
