Auto Leveling Kit PROBLEM
I just picked up my 2006 f150 crew from the ford service shop after having them install a 2' autospring leveling kit. The truck appears to be just a tad bit higher in the front.
The big problem is that i chose the 2" over the 2.5" because I am adding a topper and storage in the bed. Once this additional weight is added I will definitely be higher in the front that in the back.
Is the 2" autospring adjustable at all, would this situation be cause by the installer? What can I do?
I have the AS 2.0" kit installed in my '05 and it sits pretty level, maybe even slightly lower in the front.
I don't know that there is anything that the installer could have done to cause your situation. Probably just the differences from one vehicle to the next and from one kit to the next. Also as BalogUK stated, it may settle down a little over a short period of time.
Like you said"it could be the difference from one vehicle to the next".Because the spacers only fit on the strut one way, therefore you can't install them wrong.
A third here. I installed the 2" AS on my truck and it was higher in front by 3/4" so I got a 1.5" aal and installed it, now the rear is slightly higher than the front. It won't matter soon for me, I am going to be removing them both and lowering it instead. I know, what an idiot, function is fine but I just don't like the look.
1.5 Aal
