Anyone modify their Transmission pan for a plug?
Old Aug 25, 2006 | 06:45 PM
cpu77's Avatar
I am thinking when I change my transmission fluid. I may tap the pan and weld on a bung for a plug. This way I can change it say every 15k without dropping the pan. I would also look for a cooler that I can add a filter with. More likely I will want to do it. I hate pulling the pan
Any thoughts?
Old Aug 25, 2006 | 07:22 PM
vader716's Avatar
Nothing on your situation but I've got to drop my pan to clean out dirt in my tranny that is suspected to be there from a mountain road.
First time for me...should be interesting.
Old Aug 25, 2006 | 07:25 PM
Josiah's Avatar
I'm changing all my fluids within the next couple days, my tcase, engine oil, might do my tranny's as well and maybe the diffs. This is going to cost a fortune!
Btw, Royal Purple is incredibly hard to get a hold of, so I might stop using it.
Old Aug 25, 2006 | 07:33 PM
AlleninNM's Avatar
Are there no Napa stores in your area? I get Royal Purple there.
Old Aug 25, 2006 | 09:38 PM
cpu77's Avatar
I may just go with a aftermarket pan. Seems like alot less hassle.
Old Aug 25, 2006 | 10:06 PM
ChrisAdams's Avatar
B&M makes a kit to add a drain. Forget what I paid for the last one but it was way under 10 bucks. Easy to install, works well. Any chain autoparts place will sell them. Look near the tranny coolers.
Less work than pulling the pan, couple wrenches and a drill.
Chris
Old Aug 25, 2006 | 11:56 PM
cpu77's Avatar
Like tapping a line for a turbo's oil return Good Idea!
Old Aug 26, 2006 | 12:19 AM
ChrisAdams's Avatar
I just re-read my post.
I may have implied that you don't have to pull the pan, but with the common kit you do have to remove it to put the nut on the inside.
The Kit I use/recommend you pull the pan off, clean or replace the filter if you need to, then drill a half inch hole in the lowest part of the pan. Insert the drain and lock down the nut. The drain comes with gaskets. Then you can drain the tranny any time you want, quickly and neatly.
There is a kit you do not have to pull the pan for, uses a self tap drain plug. You drill a hole and then put in the self tap with Loctite. I recommend the other one though. No chance of metal fragments being left in the pan, and you want to clean out the pan for possible dirt anyway.
Also, you should clean the screen at least once.
Chris
Old Aug 26, 2006 | 12:40 AM
cpu77's Avatar
I will prob do a aftermarket pan. I am thinking of adding a exterior filter as well. Know anyone who has done that.
BTW my door panels showed up today they look great!
