Edge Evolution Owners,,what Are Your Settings?
Running level 2, timing +3, 93 octane. Feels much better than level 2 with 87, never tried level 3. The extra .20 a gallon seems worth it to me so far. As for 0-60 times, I still can't count that high
Running Level 3( not tried 2 yet) with 93 octane.
WOT shifts: 1-2 at 5250, 2-3 at 5250, 3-4 at 5000, Max RPMs at 5600
Normal shifts: no change
Timing: +1.0
WOT fuel: 1.8
WOT shift pressure: +12
Top speed: 110
Have done only one 0-60 and that was 8.9
I am currently monitoring Engine temp, Oil temp, Air temp, and digital speedometer. I checked the sppedometer with a Tom Tom GPS and it was registering 2 miles per hour fast.
Timing: +1.0
WOT fuel: 1.8
Top speed: 110
Im running Level 2. Its more street drive friendly since its got more torque at low rpms. Thats what I think at least.
Timing= +2 running 91
WOT-1.55
0-60=8.5 ( I got 6.95 on night on level 3 and it was bout 75 out with little humidity)
WOT-1.55
Timing: +1.0
WOT fuel: 1.8
Top speed: 110
Timing: +1.0
WOT fuel: 1.8
Top speed: 110
That time does not seem right.Do you have any other mods?i have mine on level 3 with nothing change but gear ratio and tires.MY best run was a 7.8 with 35's.. im just wondering.i have exhaust and a volant intake.. I would drop that fuel level to the 1.5. just my 2 cents.
level 3
93 performance
factory wot shifting
normal shifting 2, 4, 7
timing 1.5
shift pressure 19, 17, 12
wot fuel 1.7
0-60 8.5
i have the 4.6
93 performance
timing 1.5
wot fuel 1.7
0-60 8.5
i have the 4.6
Running lvl 2 and 89 oct for the summer
timing +.75
Shift firmness +5 on all shifts
shift point 1-2 set to +2
0-60===8.1 I have only tried runs a couple of times on lvl2. I havn't tried a run since my intake or on lvl 3 with 93 oct.
timing +.75
Is there a way to change one setting without going all the way through the reproggram?
Best way to do it is after you select "yes" for if you want to make a custom tune, go down to the bottom and select "load previous settings" then you can go in and only adjust the WOT fuel and everything else will stay the same.
[QUOTE=bluejay432000]All I have is the K & N drop in and a Flowmaster 40. The 8.9 was after driving home from work, outside temp about 103 and some humidity. It was the only time I have had an opportunity to go from a standstill. I will try the 1.5 WOT fuel setting.
ok my bad..my best run was at night and the temp was 57 outside.the only thing that i do not like is the bucking and suringing at certain speeds like around 38-40mph.other then that i love it
[QUOTE=rojoscrewkab05]
I get that bucking too, mine seems to be the overdrive going on and off. I just turn the overdrive off when I need to run those speeds and it seems OK. I have sent an email to the Edge tech dept. Hopefully, someday, they will address it?
