Black Plastic Screw
There is no way to guarantee they won't be damaged. But they make a special tool for removing them, or, if you have it around your house there is a garden tool with a v-shaped end that wraps around the base and pops the top off quite well. good luck!
I just used needle nose plyers on mine. Two of the bottow three where not holding the bottom rubber matt on and they needed to be pulled in order to put through the holes in the rubber matt.
One of them tore when pulling out with the plyers and the other came out easily. The one that tore was JB welded back together and I put it through the hole no problem.
Duke
Duke
Those things are the biggest pain in the a$$ ever. Best thing to do is dont worry about tearing them up and get new ones they are pretty cheap. Otherwise like they said they make a tool but there is no way of garunteeing they wont be damaged.
