A/c ?
Old Jul 29, 2006 | 02:00 PM
winters's Avatar
A/c ?
Has anyone noticed if there is any condensation dripping under there trucks when the a/c is running.(5.4L)
IT is hot and very humid here in Toronto the a/c seems to be cooling fine but why no water dripping, none at all. Checked the drain tube ,its not blocked and the carpet in the interior is dry.
Took it to dealer last summer they said all is fine, go figure
Any insites into this would be appreciated
Old Jul 29, 2006 | 02:03 PM
ThumperMX113's Avatar
Yup, mine always drips.
Old Jul 29, 2006 | 04:29 PM
blkscrew's Avatar
uhhh.....hope your talking about your truck there mate....
is odd that you see no water at all on the ground....even while living in southern cali. I'd always see water draining from the A/C on all my vehicles....and the humidity was always quite low....maybe best to have a hvac specialty shop have a look at it....
Old Jul 29, 2006 | 06:58 PM
Tbird69's Avatar
I'm willing to bet the drain tube is shorter then normal and the exhaust heat is evaporating the condensation before it hits the ground.
Old Jul 30, 2006 | 07:34 PM
GREG B 05 F150's Avatar
i thank that it is low on charge check the low side pipeing {the bigger of the 2} should be cold and dripping then check the high side {the small pipe} should be hot if not take it to the dealers and have them check the charge or check the compressor.
