will 6 inch pro comp clear 36
Old Jul 19, 2006 | 10:53 PM
BestNTx's Avatar
So im going with the pro comp 6 non coilover stage 1 lift kit, will this kit clear 20x10 or 20x9 (not sure what the back spacing is) moto metal 951's and 36x13.50x20 Super Swamper irok radials? i am currently running an add a leaf in the rear and 2.5 pro comp spacer up front (I realize i will have to take the front spacer out with the pro comp kit)
Old Jul 19, 2006 | 10:55 PM
allrsdup's Avatar
it might will be close with a perfect backspacing is the key.
Old Jul 19, 2006 | 10:58 PM
bigyellowtruck1's Avatar
u don't have to take the spacer out, u can be running 8.5" of lift with 36's
Old Jul 19, 2006 | 11:00 PM
BestNTx's Avatar
im going to be running the stage one (non coilover) lift which consist of a front 6 inch spacer does not look like it would be to safe to have that spacer then another 2.5 inch spacer on top of that 8.5 inch spacer lift? Am i wrong?
Old Jul 19, 2006 | 11:06 PM
ThumperMX113's Avatar
No, your right.
Old Jul 19, 2006 | 11:12 PM
its not that bad, my buddy has a pro comp lift with a spacer and never has had problems
Old Jul 19, 2006 | 11:22 PM
-TXF150-'s Avatar
If you just use the pro comp lift spacer, you should not have any problems... If you are thinking of adding a coil spacer ontop of the procomp lift spacer, I would read this thread first...
https://www.f150online.com/forums/sh...d.php?t=195990
Old Jul 19, 2006 | 11:25 PM
etrevino103186's Avatar
i am pretty sure you will be okay. i have 4.5 backspacing.
Old Jul 20, 2006 | 12:53 AM
BestNTx's Avatar
hey trevino do you have coilover or spacer lift?
Old Jul 20, 2006 | 08:18 AM
spacer
