Factory Magellan GPS
Originally Posted by whitecrystal1
ccla, How did you do that?? That's what I'm trying to figure out. I want to understand how to post my pictures like this. Thanks for getting my picture on here
Here ya go, this should help you out...
https://www.f150online.com/forums/misc.php?do=bbcode
a couple questions:
1. Do you or can you take a pic of it from the side, so i can see how much room is left in that little tray, or is it all taken up?
2. Is that a little space above the acutaly GPS unit?
3.did you install your self? was the install easy?
Originally Posted by nuclearthreat54
a couple questions:
I can still fold and fit my sunglasses in front of it, but there isn't much room at all. It does pretty much take up every inch.
I'm not sure what you mean about space on top but there is space between it and the window
Yes, I did install it. In about 20 mins. Very easy to install you could do it with your eyes closed.
Originally Posted by RockPick
I don't believe that this is a FoMoCo item... it's aftermarket.
In fact, Ford is utilizing a double-din nav system in several other FoMoCo vehicles... unfortunately though, not the F150.
I just don't like that little 3 inch screen when we have those large double dins and all the aftermarket DVD/nav systems available.
Hopefully FoMoCo will make this an option in the F-150s in 08.
I'd put a nice aftermarket one in if I was sure it would work with my steering wheel control and handle the DVD player as well.
I'll be stuck with the unit shown here if I decide to do it.
I take more pictures tomorrow night and post them.
You see where the acutal unit ends and theres a space between the unit and the housing? At the top of the acutal GPS unit.
That space on top has the volume **** and a button to repeat the last commanded direction inside it. If your looking at the picture and thinking it looks bad or anything it doesn't. It would have to be the picture and the light it was taken in. I took this picture last night in the dark. I take some more angles of it after work but it might be dark then as well.
guys......I think this is what you really are looking for....
http://www.pioneerelectronics.com/pn...ICLE%20FITMENT
