Need some help
Old Jul 11, 2006 | 10:06 AM
Vaford150's Avatar
Question Need some help
Hi All,
I have a 2004 F150 and it has suddenly developed an amazing vibration/shake as you drive. I thought it might be the tires needing air check the pressure and they are at recommend amount of pounds. Then thought it might be brakes, well when you brake there are no problems no squeak or metal on metal sound, in fact only the shaking. Any suggestions?
Old Jul 11, 2006 | 10:13 AM
05supercrew's Avatar
Originally Posted by Vaford150
Hi All,
I think it may be your e-brake, a few people have complained about that in the past.
Old Jul 11, 2006 | 10:17 AM
Vaford150's Avatar
Wouldn't I feel it more when I braked?
Old Jul 11, 2006 | 10:20 AM
No, you would feel it less. Your e-brake is a drum brake and the regular is a disc.
Old Jul 11, 2006 | 10:21 AM
Justis01's Avatar
Your e-brake is separate from the 4 wheel disc system on the truck. These are drum brakes in the rear disk hub. Sometimes they stick and cause the vibration you're experiencing. Have the shop tech check for a sticking e-brake.
Old Jul 11, 2006 | 10:23 AM
Vaford150's Avatar
[QUOTE=Justis01]Your e-brake is separate from the 4 wheel disc system on the truck. These are drum brakes in the rear disk hub. Sometimes they stick and cause the vibration you're experiencing. Have the shop tech check for a sticking e-brake.[/QUOT
Thanks I will do that!
Old Jul 11, 2006 | 10:24 AM
Vaford150's Avatar
Ok, thank you! I will have it checked.
