need advice on going bigger
Old Jul 9, 2006 | 10:53 PM
bigyellowtruck1's Avatar
okay situation, right now i have 10 inches of lift and 38 inch tires, i either want 39.5" sts or if they will fit 41x14.50x20 iroks. I'm going to add a 2.5" spacer and a 5" fabtech block, this will give me 12.5" of lift total front and back [i have a add a leaf for the back], now will 41" tires fit with 12.5"'s of lift ?
also will 12.5" of lift and 38's look stupid ? too big of a gap
Old Jul 9, 2006 | 11:50 PM
anyone ?
Old Jul 10, 2006 | 12:02 AM
ThumperMX113's Avatar
I don't think the 41s will fit, but the 40s would.
Old Jul 10, 2006 | 12:38 AM
Josiah's Avatar
Keep in mind a 12" FTS + 3" Body skies 41" Iroks. I think 41x14.5 looks scrawny, your current width looks great.
Old Jul 10, 2006 | 12:51 AM
wats the alternative ? the only 40 inch tire that has got the width i like is the toyo's but after talking to the old man $580 a tire just doesn't sound appealing, i might just lift it and keep the 38's and see how that looks
Old Jul 10, 2006 | 01:21 AM
Josiah's Avatar
I think you'll be fine with your current tire setup, post your pics and we'll photoshop a small 3" lift (2.5 roughly). Make sure you get one in there with a tape measure next to your truck if you want it to be accurate (hold the tape measure out to 5ft and stand it against the truck for best results).
Old Jul 10, 2006 | 02:04 AM
sounds good josiah, i hope this helps me decide, if it looks good i'll order the 2 1/2 " spacer and 5" block tomorow, i just want this truck to sit as high as possible, i love the feeling of looking down at every body else
Old Jul 10, 2006 | 03:43 AM
KiCk aSs FX4's Avatar
I think you should definitly go with the spacer and 5" block because I noticed those 38s do look a little jammed in. and a spacer and block are pretty cheap I assume. If it looks too weird (I doubt it will) thany you can take them off and sell them to me for cheap jk. but that photoshop would help. you also have pretty wide tires on there now and I think it will look better if it was a little higher.
Also I would be careful about those steering angles up front...you have a body lift and an spacer up front with just the stock fabtech? That might get a little scary
Old Jul 10, 2006 | 08:51 AM
treatcg's Avatar
The 5" block would be scary to me.
Old Jul 10, 2006 | 11:48 AM
-TXF150-'s Avatar
I hope you get some nice axle wrap along with that 5" block... Since you seem to have a money tree in your backyard, I would get new leaf springs instead.
Old Jul 10, 2006 | 04:45 PM
ford141's Avatar
Man, you mean 10" isn't enough? So your going to stack spacers and blocks on top of that? That sounds like a disaster waiting to happen. I think I would look at a taller kit that is actually made to go that high rather than space out the existing kit. If you have money to burn, do it right.
Old Jul 10, 2006 | 11:57 PM
no way am i gonna stack spacers, i'm just gonna order a fabtech 5" spacer and replace my 4", i'm actually looking into new leaf springs right now, i'm having problems uploading pics so i'm gonna get my buddy to u, i can't pload them onto his computer and email them me, i wanna see a photo shop with the extra lift, should look pretty sweet
Old Jul 11, 2006 | 12:42 AM
How much lift do you want out of the rear minus the 3" body?
I think you need to look into some Deaver or Atlas custom made leaf springs!!
Old Jul 11, 2006 | 01:07 AM
minus the body lift it will be 8.5, thats what i want anyways
Old Jul 11, 2006 | 01:13 AM
where are them pics??
