truck sluggish...help?
Old Jun 28, 2006 | 09:28 AM
05supercrew's Avatar
Did anyone reprogram your computer to know that you have 4.88 gears if not your truck is trying to shift like you have 3.55. Like others said get a programer right away.
Old Jun 28, 2006 | 09:32 AM
etrevino103186's Avatar
Originally Posted by fx4jake31
that'd be low... higher number=lower gear...
i guess boredom makes you critical....
well whatever the technical term is.those gears should make a substantial change from my 3.55's. i have decided to just play the waiting game and drive it for myself. However I am going to order the edge in the next hour or so. I will be sure to keep you all updated and to post pics when I get a chance I only have a couple pictures, which where taken at night because I was desperate.
Old Jun 28, 2006 | 09:35 AM
Truck looks great but if your computer was not changed do not drive your truck, you could mess up your tranny.
Old Jun 28, 2006 | 12:54 PM
sparkysvt's Avatar
i would dump the glasspacks and get you a nice magnaflow muffler. dual in dual out, they have a built in x pipe in them. and if you do a lot of interstate driving i wouldn't get flowmasters. they drone to much for me. at 85 on the interstate you can't hear my exhaust if your talking and the radio is on. but if you goose it the beast comes alive
Old Jun 28, 2006 | 01:15 PM
Sal FX4's Avatar
Not necessarily, The 4.88s should put it closer to stock i.e. the computer still shifts at stock shift points since the gears compensate for the larger tires. If he had NOT upgraded his gears then the computer would shift at the wrong shift points. I dont know how to explain clearly but you should get the idea.
Anyways, I would probably drive it YOURSELF before you freak out just like Thumper said. I drove my truck to the shop with 3.73s and 37s and had to turn the overdrive off and manually shift because the shift points were off like a ******. After the gears, the shift points were back to normal BUT lacked power...I wonder why? Anyways, If it were my truck I would definately dump the glass packs and get a muffler with some back pressure, then i would install the EDGE, no doubt about it. The edge will fix your shift points and give you the accleration you want.
Just my 2 cents
Old Jun 28, 2006 | 01:20 PM
ThumperMX113's Avatar
Are you running 37s on just a 6" lift?
Old Jun 28, 2006 | 01:56 PM
yessir. my dad said it rubs a lil at full lock but not enough for him to itch about only because i asked. plus i haven't trimmed anything..
btw thanks everyone for all the help i can't wait to drive it tomorrow. how many miles do i have to let the gears settle for before i can romp on it? my dad told me 1000 but i think he was messing with me
Old Jun 29, 2006 | 08:43 AM
SSpiro's Avatar
For the record, my Flowmaster 40's only drone at around 50mph..
I can't hear it on the highway with the windows down and radio off..
Old Jun 29, 2006 | 09:16 AM
allrsdup's Avatar
truck looks great red is very sharp color on these trucks i am starting to notice
Old Jun 29, 2006 | 09:27 AM
flashbang756's Avatar
+1! Please remove the glasspacks! Those are reserved for only chebby and dodge owners!!
I'm sure, as Sal said, that a muffler with some better backpressure will help out tremendously. Along with a good tuner.
Old Jun 29, 2006 | 02:36 PM
Sal FX4's Avatar
If I remember correctly, The guy who did my gears said 1000 miles also. You may want to have the gear oil changed after you break them in.
Old Jun 30, 2006 | 12:49 AM
How did you do it?! I am at about 350, 300 of which my dad put on. The engine just wants to hit wot.
