post you custom edge tune
Old Jun 25, 2006 | 02:54 PM
Adam06FX4's Avatar
Registered User
what have you guys changed on your edge to give you the most power and fastest times. so far ive just changed the shift firmness on lvl 2 but i see all you guys getting like 15.5 1/4s and im getting like 16.8. whats the secret?
Old Jun 25, 2006 | 05:25 PM
The professor's Avatar
Yeah i would also like to know what you guys have yours set on because my fastest 1/4 time is a 17.5 but thats also with a 5 gallon air compressor, a tool box that is probably pushing 150 lbs, and a passenger. Thats on level 2 running 87 octane also. When i get my CAI and run some 91 octane on level 3 maybe i can get in the 16's. I raced a V6 stang the other night and we were neck and neck for the first 60 mph or so then he left me. I spun tires off the line a little to.
Old Jun 25, 2006 | 06:02 PM
ThumperMX113's Avatar
This is what Im running right now, I used to run a LOT more aggressive tune on my last truck and all was fine.
  • 1-2 WOT SHIFT: 5200 rpms
  • 2-3 WOT SHIFT: 5200 rpms
  • 3-4 WOT SHIFT: 4700 rpms
  • SHIFT FIRMNESS 1-2: +5
  • SHIFT FIRMNESS 2-3: +5
  • SHIFT FIRMNESS 3-4: +0
  • REV LIMITER: 5400 rpms
  • WOT FUEL: 1.3%
  • TIMING: + .25
I think thats it. .
Old Jun 25, 2006 | 07:57 PM
Matt 05'FX4's Avatar
17.5! Wow.....But it does have a lot to do with the weather also. My stock Roush tune uncorrected times were about 9.6-9.7 with the best being a 9.500 (14.9 1/4 mile) but that was on a fairly good afternoon with low humidity and around 75 degrees. I went back the other night and got a SLOW 10.0 and it was 95 with SUPER high humidity and major wheelspin off the line. That was with a full tank of gas (35 gallon tank) and all the other crap I have (tonnea, spare, 75lbs of traction bars)
Old Jun 25, 2006 | 09:55 PM
RobNY's Avatar
Matt 05'FX4,
Not to get off subject but i thought you were Bama tuned not M.T.?
Old Jun 25, 2006 | 10:50 PM
mkinttrim's Avatar
I'm at 5300 FT so just running the stock tunes right now. I am running level 2 at 85 octane with no problems and have run level 3 at 88 octane without any problems. If there are others at altitude that are running custom levels I'd love to hear from you.
Old Jun 29, 2006 | 04:12 AM
xplorgee's Avatar
IVe seen some guys running +15 on their shift firmness. I saw in the manuall that it might be bad for the tranny if you change some of the settings to sudden. I guess you have to break it in. I was playing with the shift firmness and it goes all the way up to 25. Has anyone done thise.
Old Jun 29, 2006 | 04:18 AM
SnowmaNick
Guest
Posts: n/a
  • WOT FUEL: 1.3%
  • TIMING: + .25
I think thats it. .
I decided to try out your tune on level three. Rather mellow but very streetable.
Old Jun 29, 2006 | 07:11 AM
PHS79's Avatar
Here is what I am currently running:
lvl2 with 89 oct.
shift firmness +5 on all shifts (I used to run +15 on all shifts on lvl3)
shift point +2 on 1-2, rest are stock
timing +1.00
The reason that I don't run +15 on the shift firmness is because I started to pull trailers more, and I figured that a high shift firmness and a few thousand pounds was a bad comination. My best 0-60 so far is 8.1, I did think that was too bad at all. I havnt done any 1/4 mile runs.
Old Jun 29, 2006 | 07:40 AM
Silverfish's Avatar
Read signature.....
