plastic screws
Old Jun 22, 2006 | 07:57 PM
redman_a12's Avatar
plastic screws
I am trying to remove the fan/belt cover to open up the engine bay some more. The 6 or so plastic screws that hold the thing on...only one screw came out, the rest just spin. Any trick to getting these out?
Old Jun 22, 2006 | 08:04 PM
redman_a12's Avatar
nevermind....hold a flat screw driver under it while using a phillips to unscrew the screw. I just was trying to avoid breaking any thing
Old Jun 22, 2006 | 08:28 PM
Quintin's Avatar
Or just jam a small flat blade screwdriver or a straight pick between the screw portion and the outside of it, pry the center out.
Old Jun 22, 2006 | 09:57 PM
RamSS/T's Avatar
You do know that the fan shroud is actually a pretty important part of the cooling system don't you? It helps the fans efficiency by causing it to pull air through the radiator rather than from around it. When electric fans are added most have a small shroud around them but they are also a lot closer to the radiator than the factory fan....thats why you can remove the shroud when your running electric fans. I am not sure how much it will hurt the cooling system but I wouldn't think its worth taking it off just to clean the engine bay up a little.
Old Jun 22, 2006 | 10:18 PM
Quintin's Avatar
I don't think he's removing the shroud itself, I think he's removing the cover that goes over the shroud on the core support, the thing that has the underhood info, emissions stuff, vacuum diagrams, etc.
Old Jun 22, 2006 | 10:29 PM
RamSS/T's Avatar
Maybe your right....but he said he was "trying to remove the fan/belt cover to open up the engine bay some more". The cover your talking about doesnt cover the the fan or belt and removing wouldnt open up the engine bay too much all....thats why I think he is talking about the fan shroud.
Old Jun 23, 2006 | 12:19 PM
redman_a12's Avatar
Yes, Allow my self.... to correct myself.....I was just removing the very top horizontal plastic piece that covers the top of the radiator. I left on the cover that actually covers the fan itself. I just want the engine bay to look less plastic-y and more open like the old muscle cars
Old Jun 23, 2006 | 04:16 PM
RamSS/T's Avatar
OK...that makes a lot more sense to do!
