LT Handles went up. .
#31
I pulled the horseshoe clip off that is pointed at with the arrows - with an awl. A needle nose is a little overkill for the space you have when the lock rod is still connected. Just pry it out and pull it off the rest of the way - 1,2,3.
I installed the lock mechanism and clip when I had the rods and wiring connected, also no problem.
Honestly, you can use whatever you want to get the clip off.
#33
Well since you called it a GREAT write up I guess I can post it for ya
Hope it helps
https://www.f150online.com/forums/sh...d.php?t=235715
Hope it helps
#34
Hope it helps
Hope it helps
#36
Originally Posted by ThumperMX113
I cant wait, they will be here tomorrow!
The top outside corner comes in contact pretty good when you twist it in to place. Just tape real good on that corner and metal edges of the handle opening.
#38
#40
#41
#42
I was thinking about ordering the 5" block and having them crank my coilovers an inch to level it back out. What do you think?
#44
#45
