325/60/18 on stock wheels
Old Jun 15, 2006 | 08:46 PM
Devin4X4's Avatar
Hey guys quick question....after much deliberation on which tire to get im gonna go with the nitto terra grappler. I've changed my mind countlesssssss times but this is what i've settled on. I think im going to put the 325/60/18 terra grapplers on my stock fx4 wheel. Just want to make 100% sure they will fit. I think i remember seeing pics of someone on here with this size but not sure. thanks
Old Jun 15, 2006 | 09:48 PM
fx4jake31's Avatar
i've got them look in my gallery
Old Jun 15, 2006 | 10:06 PM
tardman91's Avatar
Those look sweet. You just have the 2" AS? Do you get any rubbing at all?
Old Jun 15, 2006 | 10:54 PM
fx4jake31's Avatar
only when i crank the wheel all the way
Old Jun 15, 2006 | 11:08 PM
BalogUK's Avatar
keep your pressure and alignement on check and you should be good to go devin- they are a teensy bit to wide (even by their reccomendationss) for the stock wheel, but i'd say you're good to go- man tryin to find tires that fit sucks doesn't it!!!
J
Old Jun 16, 2006 | 06:12 PM
mountainar15's Avatar
I had Toyo 325/60R18s on my stock wheels for a long time. Rubbed on the lower control arm at full turn. Other than that, they were fine. You can see them in my gallery.
Old Jun 16, 2006 | 06:24 PM
Stragum's Avatar
yeah, you just cannot beat those stock rims....they are nice!
Old Jun 16, 2006 | 07:09 PM
Nebraska's Avatar
You should be fine. I have 325/60/20's on OEMs with a AS 2". I have rubbing on the upper A arm at full tirn, but the look is worth a 3 point turn every once in a while!
Nebraska
Old Jun 16, 2006 | 09:40 PM
YOMAN's Avatar
Have you take your truck off roading? any fender rubbing ??
DO you guys notice theres quick wear on the middle than edge tire? what psi do you guy running?
Thanks!
YOMAN!
Old Jun 17, 2006 | 01:53 AM
BalogUK's Avatar
i ran 45psi in the summer, and 50 psi winter on my 33" toyo mt's rotated every oil change, which based on harsh driving conditions is every 3-4k miles. I had perfect wear unitl my left hdrivers toe alignment went under spec by -1.2pts.
i am running 45 psi on my 35" procomp xterrain now.
