Click, Click, Click, Click
Old Jun 7, 2006 | 11:02 AM
slash123's Avatar
Hey guys. I am getting a rotational clicking from my drivers side front wheel. It is intermittent and there is no rhyme or reason to it and sometimes it is louder than others. I thought maybe something was stuck in the tire treads, but there is nothing in the treads causing this.
Last night when it started clicking, I put it in 4 Wheel High to see if it changed at all, but it didn't. I did notice that I couldn't hear the hubs engaging, but I could tell they were engaged when I made a couple of sharp turns. Any ideas? I've read on here that it might be a vacuum control solenoid, but I'm not sure. Thanks for the help
Old Jun 7, 2006 | 11:08 AM
ThumperMX113's Avatar
The hub will need to be replaced.
Old Jun 7, 2006 | 12:51 PM
slash123's Avatar
How do you know this?
Old Jun 7, 2006 | 01:04 PM
FX4Cody's Avatar
Thats what happened to thumper,I think.
Old Jun 7, 2006 | 01:08 PM
My passenger side hub was completely ruined and it'd make the same noise. My dealer ended up replacing both hubs though.
Old Jun 7, 2006 | 02:51 PM
slash123's Avatar
did they say what caused it?
Old Jun 7, 2006 | 02:52 PM
Nope.
Old Jun 7, 2006 | 03:56 PM
wasachevyguy's Avatar
that sucks. when it happened to me it just turned out to be a stone in the tire tread.
Old Jun 8, 2006 | 07:56 AM
Rochester's Avatar
If there is no rhyme or reason to the noise and it is intermittent, how do you know it is rotational? A rotational noise would suggest a noise the increases or decreases with speed or the noise occurs at a specific frequency. Are you sure it is not your air conditioning cycling on and off? That sounds like an intermittent click that happens quite often.
Old Jun 8, 2006 | 08:29 AM
PenguinFX4's Avatar
Sounds like hubs to me as well.
I had a similiar issue with the passenger side.
Old Jun 8, 2006 | 08:36 AM
slash123's Avatar
I mean there is no ryme or reason to when it starts the clicking. Once it starts it is definatley rotational. I am positive its not the AC.
Old Sep 17, 2006 | 03:25 PM
slash123's Avatar
Well I finally figured out what the noise is. It is the factory "chrome clad wheels." Ever since I put on my BFG A/T KO with the rim guard this had been happening. It started out as only one wheel, but it is slowly happening to all 4of them. It drives me insane! Anyone no any good websites for good cheap chrome wheels?
Old Sep 17, 2006 | 03:40 PM
truckskills's Avatar
I had the same problem. I just replaced with the FX4 18s. As for a good place online for new ones, check out www.4wheelparts.com, or pro comp website. It just depends on your taste.
Old Sep 18, 2006 | 01:44 AM
jlong20's Avatar
www.customwheelsdirect.com
Old Sep 18, 2006 | 08:46 AM
mlawdawg's Avatar
Is this like a chirping noise almost? I have been getting that from the rear and thought it was maybe the brakkes.
