LED tails?
Originally Posted by Xterrable
I stand corrected. I did find the website. The bulbs for our trucks were 45 bucks a piece.. Anyone want to be the test dummy??
http://www.spiderlite.com/store.html
Does it depend on how much room is inside the light housing?
I'll post pictures once they arrive (assume I figure out what size and place the order)
I actually put a post on this a few months ago and I was a little hesistant to try these. I did write the manufacturer and got the correct part number. I'll see if I can find the e-mail and i'll let you guys know.
original Spider light post.......hopefully this helps a little.
https://www.f150online.com/forums/sh...d.php?t=223148
Yes if you just install LED turn signals or in our case the tailight/turn signal you need to add a resistor or because of the low current draw the truck will think it is burned out and cause it to flash rapidly
Originally Posted by nuclearthreat54
Depo makes really nice black LED lights, WITH NO BUMP, sorry. I had to put that out there
Originally Posted by RUSS04
Are they PLUG & PLAY ? Do you have to add a resistor ? Would they look good on a med wedgewood blue truck ? Thanks
Originally Posted by 04procompLARIAT
Wasnt somebody on here talking about a set of LED tails that HIDplanet was gonna come out with?
The nice thing about them is that they include the resistor pack with heat sink to allow proper flash rate of the lamps.
The con is that the LEDs used in the tails are mainly there for the brake cycle and not the parking cycle. Only the bottom 1/4th of the lamp is used during parking lamp cycle, and the top 3/4 lights up only when braking.
I am going to customize them so they all turn on during parking and light up brighter when brankes or turn signals are applied, BUT this is an option I could NOT provide when selling them because of the custom nature of a circuit board and wiring.
Another con is that the price point for these units is high. Just as high as some of the other units and people do not seem to want to spend a few hundred dollars for items like this.
