E-Fans in
Originally Posted by ThumperMX113
Eric, you should consider creating a package like your set-up and selling it to members.
That's probably what makes the pre-packaged setups available so expensive. It's not the parts, but the built in CYA surcharge just in case something goes wrong.
BTW - For those who have the TP setup - Who is the fan manufacturer?
E...
i finally got mine installed as well. i didnt like the kit deal so i built my whole set up. im using two flexalite 398 syclone fans and a dc controller. 2500 cfm each. and the controller is a variable voltage controller. i didnt like the fans being suspended from the fins so i built some brackets. i also have a switch to cut out the a/c signal when on the freeway. www.dccontrol.com is the controller i have. i will take some pics tomorrow.
