Mag Hytec diff cover... pics
Old May 24, 2006 | 08:58 PM
03SNKE's Avatar
Just installed it yesterday. Cool peice with the magnetic dip stick and 5.1qt capacity as opposed to 2.7qt - Powder coated black with the machined fins- high quality peice. Filled her up with 75W140 Royal Purple, and at 10 bucks a quart it wasnt cheap, but I figured it should last me a good 80k so I might as well get the good stuff.
Old May 24, 2006 | 09:01 PM
06FX4's Avatar
that looks great!!! where did you get it?
Old May 24, 2006 | 09:02 PM
killedbyaspoon's Avatar
Did you put some friction modifier in it.
InCuBuS's Avatar
man that looks great
Old May 24, 2006 | 09:04 PM
roushlimited's Avatar
I like it alot... that would look really good on a lifted truck.
Old May 24, 2006 | 09:21 PM
MTpint's Avatar
I got one!! its sitting in my garage waiting for my gears That looks real good
Old May 24, 2006 | 09:24 PM
nuclearthreat54's Avatar
aaaaaa Nice!! I wanna get one bad....well two because im 4wd
03SNKE's Avatar
Royal Purple comes with a friction modifier already in it. Another reason I used to justify the cost.
Thanks for the compliments... I got mine thru maghytec.com for $250
EDIT- Now I want the trans pan to match!
Old May 24, 2006 | 09:27 PM
I have a question, do they make a front diff cover?
Old May 24, 2006 | 09:40 PM
03SNKE's Avatar
They do make one for the 8.8, I dont know if the reversed ones we have up front have a different cover but I dont see why not
Old May 24, 2006 | 10:56 PM
Verado300's Avatar
The guys that put my gears in used royal purple after break in and I knew that it already had the modifier in it, but they added two little bottles of it anyways. Not only that, they filled it through the abs sensor at the top of the diff cover, and when fluid came out the plug hole they plugged it and put in a couple more pumps of oil since it was in a 5 gallon royal purple containter I hope its ok, so far so good…….I plan to change it in 30K, when I do, I will do it myself with a mag tech cover...did you use a gasket or silicon??? They used high temp RTV silicon to seal my covers….I was worried about it not being fully cured when I drove off after they did the switch from break in oil to synthetic….O well, everything seems fine and its been about 1500 miles.....
Old May 25, 2006 | 01:19 AM
bamorris2's Avatar
Not good... Overfilling can cause it to "froth-up" (I know there's a better word that I can't think of)... Not good.
Mag-hytech's come with a rubber o-ring. No need for gasket or silicon!
Old May 25, 2006 | 02:28 AM
AirborneRacer's Avatar
I have always liked the look and quality of those covers. Not cheap but they are sharp and good quality. Enjoy
Old May 25, 2006 | 06:27 AM
mlawdawg's Avatar
Nice. Can't wait until mine arrives.
Old May 25, 2006 | 09:39 AM
05supercrew's Avatar
That look nice. Thanks something else to the list.
