Tranny door code A??
Old May 19, 2006 | 04:10 PM
fordworker's Avatar
I waslooking through my manual and it doesnt say what type of Tranny I have. The door code says A. Its not listed in the manual??? I was looking for because apparently only certain types need to be serviced. Thanks for the help!
Old May 21, 2006 | 11:25 AM
fordworker's Avatar
no one else has a door code A for the transmission?
Old May 21, 2006 | 11:36 AM
anaheim's Avatar
You have the 4r70e transmission. I also have the "A".
Old May 21, 2006 | 11:58 AM
fordworker's Avatar
Thank you for the replay..so what about service on this transmission?
Old May 21, 2006 | 12:05 PM
anaheim's Avatar
I believe the tranny should be serviced (flushed) at 30,000 miles.
Old May 21, 2006 | 12:59 PM
adrianspeeder's Avatar
Come on up to the tranny section, you would have found this...
https://www.f150online.com/forums/sh...d.php?t=211867
A in '04 is the 4R70w. Light duty auto tranny introduced in 1994. Flush it every 30K with Mercon V and you will be good.
Adrianspeeder
Old May 21, 2006 | 01:39 PM
anaheim's Avatar
Adrianspeeder
"W" ?, if thats true, Rockyjsquirrel gave be incorrect information in a previous post.
Old May 21, 2006 | 02:40 PM
Matt 05'FX4's Avatar
So the 4R75E can handle 750 ft lbs torque??? That is awesome!
Old May 21, 2006 | 03:07 PM
Wookie's Avatar
That number is after the torque converter. So if you were to connect a 750 ft-lb engine to the tranny something will go boom. The trans can be upgraded rather easily to withstand quite a bit more power. Search the tranny forum there is a link somewhere to a Cougar/T-Bird board that has an article written by a former Ford Powertrain Engineer that lists what needs to be changed. The article was for the 4R70E, but I think that the 4R75E is nearly identical.
Joe
Old May 23, 2006 | 04:51 PM
After the force multiplication of the torque converter. Don't be hookin up big block power and expect it to hold together...
Adrianspeeder
