Which Brand 6" lift for 06 Screw?
Old May 15, 2006 | 05:56 PM
CRFracer's Avatar
I don't travel the Rubicon very often in my trucks as I'm not fond of dents and broken parts, so I don't really need the most compliant suspension out there. I'm wanting to lift the truck so I can install 35" tires on it and make it look like a truck should. I can get a Pro Comp 6" lift kit for $1395 while Fab Tech, RCD and Rize are much, much more. Is there any good reason why I should stay away from Pro Comp's lift kit? I really don't want to compromise the ride either, so can I expect the ride quality to remain the same with any of these lift kits installed? Thanks, Mike.
Old May 15, 2006 | 06:03 PM
patshea098's Avatar
pro comp is a greta brand....i have it.....with coilovers in the front and rear MX-6R shocks......but the kit your looking at is the most basic kit.....rear replacement shocks ES300's and the front just has spacers.....not new shocks...thats why its only 1395
now mine was 2400 with the front Pro Runner Coilovers
and rear MX-6Reservoir shocks instead of the regular MX-6 shocks
Old May 15, 2006 | 06:07 PM
-TXF150-'s Avatar
Unless you plan on going with coilovers, I would not go with pro-comp just because of the fact that their basic kit uses spacers to raise the front...
Old May 15, 2006 | 06:36 PM
ThumperMX113's Avatar
Exactly, but you can get the ProComp kit with coilovers for around $2,000 through 4WP.
