[PICS] Good, clean fun...(sorta)
Old May 15, 2006 | 04:12 PM
ThumperMX113's Avatar
Originally Posted by N2 TRBL
Not particularly, why?...should I?
I'd say so. Water gets into everything. .
Old May 15, 2006 | 04:29 PM
N2 TRBL's Avatar
hmmm...I thought that everything was sealed up? Gimme an example of "everything"...
Old May 15, 2006 | 04:32 PM
Well I believe the front end, rear end, transmission all have breathers where it would let water inside.
Old May 15, 2006 | 04:39 PM
N2 TRBL's Avatar
oh snap...lemme check
Old May 15, 2006 | 05:31 PM
04 RED LARIAT's Avatar
If I scroll thru the pics fast enough I think I can follow the action.
I don't think you have any worrys with the water depth you are in. I have had mine in water up to the bottom of the doors with no contamination.
Old May 15, 2006 | 05:46 PM
quackrstackr's Avatar
If I'm not mistaken, there is a recommendation in the owner's manual to change the fluids when you submerge the front and rear diffs.
That being said, I think that's probably a bit overkill and have had previous trucks up to the bumpers in water without ever having a fluid problem.
Old May 15, 2006 | 06:08 PM
Josiah's Avatar
You should be fine if you were just splashing around. You have breather tubes that extend up into the engine bay, I can't recall if the rear had one.
