Problem: Engine Tick/Clank/Delay at WOT (5.4 3v)
Old May 8, 2006 | 03:30 PM
Lumadar's Avatar
Exclamation Problem: Engine Tick/Clank/Delay at WOT (5.4 3v)
Hi all-
I've got a 2005 5.4 and I noticed that ever since I loaded my custom tunes (xcal2) when I go from a stop (no throttle) and go straight into WOT (Like at a drag strip) the engine makes a metal clanking sound that is audible inside the cab, and especially outside the truck.
It does it on the 87 octane and 91 octane, before and after learning cycles.
The only other thing I can thing of that might be related is that since day one the truck has made a somewhat similar sound occasionally when it turns over, AND every now and then the truck won't turn over and I have to crank it twice.
ANY ideas on what this might be?
*No one has any idea what might make noise when the engine goes into WOT from a stop?
Old May 8, 2006 | 05:47 PM
StuckInMuck's Avatar
are you sure the metal clanking noise isn't coming from your muffler?
Old May 8, 2006 | 06:23 PM
kelmvor's Avatar
I have a similar noise. It comes from under my feet, sounds like metal pinging noise, but it's not the engine i'm pretty sure Yea, i have a tune on it from my 1714.....sure would like to know myself. been there since day one
Old May 8, 2006 | 06:40 PM
Matt 05'FX4's Avatar
Sounds like spark knock to me........Mine did it untill I pulled back the timing 2 degrees......
Old May 8, 2006 | 06:48 PM
03SNKE's Avatar
Youre not alone. I have a troyer tuned xcal2 with the same issue, DETONATION from a stand still when you stab the throttle. The wierd part is that it only does it when the engine isnt under load, just for that quick second before the gear engages. Ive been meaning to talk to troyer about it but havent had the chance, anyone elses input would be appriciated
Id also like to add that I have played with timing a bit to no avail... just poor performance. Hell, it will even do it on an 87 tune with 92 in the tank!
Old May 8, 2006 | 08:46 PM
Lumadar's Avatar
Definitely not my muffler. It's from the very front of the truck, it was LOUD, and it sounded almost "mechanical" but then again I don't know what detonation should sound like.
It almost sounds like throwing some pennies into a tin can or something.
Old May 8, 2006 | 08:59 PM
Yep that's pinging/detonation and it is NOT good. Get that fixed asap or you might be ruining some plugs or your engine.......... Back the timing off a few degrees for starters, and tell your tuner to back off the timing on tip in, so when you initially give it throttle, it won't knock.
Old May 8, 2006 | 09:21 PM
Quintin's Avatar
A 2005 engine should have PZT-1FE plugs in it as well, although some early builds may have slipped through the cracks with the 2FEs which are slightly hotter than what Ford recommends now as a service plug. This may promote some of your detonation that you're experiencing. It's a reach, but it's all I can think of right now. Might wanna give Troyer a buzz and see what he says too.
Old May 8, 2006 | 09:25 PM
Lumadar's Avatar
Thanks for the info. I think my truck was an early 05 build, so that very well may be contributing.
Once again, I appreciate the help guys.
Can I go in with the xcal2 and adjust the timing without having to re-install the tune?
Old May 8, 2006 | 09:26 PM
Quintin's Avatar
I haven't got a clue how the XCAL2 works and what/how you can adjust stuff.
Old May 9, 2006 | 12:16 AM
zachespo's Avatar
My truck is doing the same thing. I have an edge on level two with timing increased to 1.25 running 87 Octane. I will decrease the timing tommorrow and see if that changes anything. Do you have to remove the plugs to see what type you have?
Old May 9, 2006 | 09:14 PM
Mine was a January 05' build and it had the PZT2F's in it, I had spark knocking problems exactly like this on my stock Xcal tune for both 87 and 93 tunes. If your Xcal is setup right, you can go to options right before you flash the tune to the truck and adjust spark trim from low RPM to high RPM in like 3 different segments. I would take 2 degrees out of the low RPM timing to be safe. I would also get these new PZT1F plugs. Roush sent me these when they updated my PCM but now I wonder if I should go with Autolite HT0's for an even colder heat range........
