Trailer wiring question
My new boat has surge brakes on it. I found a connector that should work for the 7-way (truck) to 5-way (trailer). On the 7-way on the truck is there a pin for power coming from the reverse lights. Just want to make sure I don't have to do any splicing or anything.
Don't know for sure, it should with the rv plug. Here is a link for the plug diagram you can use a test light to make sure.
http://www.marksrv.com/wiring.htm
Where were you able to find a 7 to 5 way connector? I havent been able to find one for my boat with surge breaks.. Everytime i want to back up i have been getting out and pulling the wiring out and stick turing it so i can stick the surge break pin into the truck. (As i only have a 4 way connector)
http://www.shipstore.com/SS/HTML/AND/ANDV5415.html
http://www.championtrailers.com/TRAILER_RECEPTACLES.htm
http://cgi.ebay.com/ebaymotors/7-TO-...temZ4616532969
I have found them on the internet but haven't looked locally yet. Going to check this week sometime.
Surge brakes are not the issue. Surge actuated DISC brakes are. Surge actuated DRUM brakes only need a flat 4 connector. Drum brakes on a trailer do not have enough stopping force in reverse to stop your vehicle. Disc brakes do and therefore require a solenoid to literally block the trailer brake line when you back up. That's why the blue wire (hooked to your backup lights) is used as the 5th wire on a flat 5 connector. Yes, your 7 pin connector from the factory Class III Towing Package has that.
So then just getting the 7-5way adapter should allow me to back up without the brakes engaging. This is on a Ranger boat trailer by the way. I also have a brake controller for another trailer that I pull with e-brakes on it. The boat trailer just has surge brakes. Not sure if they are drum or disc.
