OEM Fender flares??
Old May 2, 2006 | 11:32 AM
sgerry's Avatar
OEM Fender flares??
FX4/Lariat fender flares, can they be purchased from the dealer?
How are they attached?
Old May 2, 2006 | 12:23 PM
BalogUK's Avatar
yes you can purchase the flares online, or order thru your dealer- I have found them on ebay as well as at www.fastpartsnetwork.com
Old May 2, 2006 | 11:00 PM
TrukMupper's Avatar
To attach them you need to make a template and be prepared to drill 72 holes in your fender wells. No kidding..72 holes.
Old May 2, 2006 | 11:05 PM
piece of cake.
Old May 2, 2006 | 11:17 PM
TrukMupper's Avatar
Originally Posted by Stealth
piece of cake.
It was a 4 layer double chocolate for me so I spent about 4 hours and excercised extreme care so I could have the ice-cream with it
Old May 2, 2006 | 11:18 PM
Old May 3, 2006 | 12:24 AM
wasachevyguy's Avatar
buy them from me and save yourself about $400.00
Old May 3, 2006 | 12:28 AM
RobNY's Avatar
If there from a Lariat ,send me an email and let me know how much.......
Old May 3, 2006 | 12:49 AM
AZDesertRat's Avatar
I just added these to mine. I didn't drill the holes in the body only inside the fender lips. They went on pretty good that way. There is a guy in Texas that sells them on e-bay and goes by loanstarford. The dealer wanted $400 unpainted and install myself.
Old May 3, 2006 | 01:16 PM
gchuff's Avatar
Used FX4 Flairs for tmplates
I installed the Lariat flairs on my XLT last weekend. Last year I purchased
a set of black FX4 flairs real cheap off ebay and have been waiting for Lariat
flairs. I also purchased mine from loanstarford as mentioned above. Since I work in a tool shop, I took one of the clips that is used to hold the flair on
and installed a small drill bushing in it and then at each location on the FX4 flairs I drilled a small hole all the way thru. Then I put blue painters tape on the fenders and after clamping the FX4 flairs in place, I used a small drill to
"spot" drill all the locations. Then I removed the FX4 flairs, drilled the holes,
painted the raw edges of the drilled holes and installed the Lariat flairs.
They fit perfectly. The first one was the scariest. Drilling those holes into
perfectly good sheet metal.
Old May 4, 2006 | 12:47 AM
sorry, they're from an FX4
