rear air bags...
Old Apr 29, 2006 | 10:12 PM
bofer's Avatar
rear air bags...
hey guys,
anybody on here use the ford factory towing airbags. they are 150 installed and can support ALOT of weight. i dont pull stuff that often, but with my truck leveled out and 35s on there, it will look horrible and ride horrible and these i thought would be a good compromise. anyway, tell me what you think
Old Apr 29, 2006 | 10:50 PM
cobraman302's Avatar
Can you tell me more about these Ford airbags? I have been thinking about getting some airbags to tow my camper with, since my truck sits level without a load on it. And that seems like an awefully good price. Is that Ford installing them? Or a personal mechanic? Are they just support bags, or do they inflate? Thanks man.
Old Apr 29, 2006 | 11:24 PM
bofer's Avatar
they inflate, i think they actually might be made by firestone
Old Apr 29, 2006 | 11:43 PM
Bayouscrew's Avatar
Thumbs up I have the firestone airbags
I have the front leveling kit and haul my 4 wheeler and pull heavy trailers a lot. Adding the airbags keeps the trucks bumper off the ground and the front from nosing up when I do this. They are easy to install about 2 hours, alone, & no air tools. Had to open up the brackets a little with a sledge hammer to fit around the frame rails but I am very satisfied with their function. I don't have the air compressor I just put in a T fitting and put both airbags to one valvle stem near the license plate. When not hauling keep 2-3 lbs of air so the ride is not rough. Just try not to lift the truck from the frame much and if you do deflate the bags completely.
Old Apr 30, 2006 | 01:10 PM
Fritz_H's Avatar
I had the Firestone bags on my '01 because my little tent trailer and a bed load of camping supplies was enough to drop the rear quite a bit. The air bags were pretty easy to install (had to drill the frame, newer versions are no-drill, I understand) and kept the ride level. Never experienced any harshness at all.
