Question for those of you with the Ford 6 disc/mp3 player
Originally Posted by SSCULLY
You are making a WMA data CD, and finalizing it, and it plays, or are you using Windows Media Player with WMA files, and burning a CD ?
Originally Posted by white93
I have a 6 disc changer/MP3 from a 2005 F-150. I bought it off Ebay. I burn WMA using Windows Media Player and it plays them just fine.
Originally Posted by vader716
my guess is he is actually just creating a standard audio CD with 60/74 minutes of music
The burn function in Windows MP makes an audio CD, not a MP3 / WMA cd.
Originally Posted by Tbird69
This must be the confusion. I guess I should have made the question clearer. What I meant was does it play the WMA files you have to burn using the data format, not the standard audio format that Windows Media Player burns with by default.
I understood what you meant, no problem....short answer....No.
The plastic cover with the clip tab on it, did you have to cut that off ?
The SMB connector on the Sirius Factory rcvr had the square shroud around it, with the clip tab, to hold it into the factory rcvr.
The Starmate when I had it installed in the truck, the SMB connector did not have the clip tab cover on it, just the SMB connector on the end of the cable.
Also the Sirius Factory rcvr I got from the Visteon dist, did not have a strain relief end on the antenna wire, so if you have a PnP unit, and move it into the house, you would need to be careful not to mess up the end of the cable, plugging and un plugging it.
The above quote explains what I was referring to in my previous post.
