E-fan Fuse Question
E-fan Fuse Question
Hey everyone,
I installed my e-fans a couple of months back. Well i was never able to figure out the ignition source to tap into, so i just wired it up through i different source.
I want to correct this so it is hooked up the proper way..
Does anyone know what Fuse # it is that you tap into in the fuse box for the ignition source?
Thanks,
Nick
Thanks,
Nick
Nevermind.. I figured it out.. I pulled out a DMM and went to work on the fuse box.. Fuse #18 worked really well. It is only hot when the truck is in the run/start modes..
This way i can sit in my truck and listen to the radio if i get somewhere early and not have to let the fans run for those 15-20 minutes..
