Couple easy Qs
Couple easy Qs
I have not been able to find silverstars for my 05 at any local stores.They tell me I need H13 bulbs is that correct?Any other size/type that will work?
Any one know of a chin spoiler/air dam that has fog light provisions?My stx has no fogs and I want to add them and the ford lower bumper is too much $$$
I want them to look factory installed.
I have a kicker L7 10" sub that came from kicker in a wedge type box and want a good under seat box to replace it.What have you folks found to be a good box that fits?Where did you get yours?I like the JL box but it seems hard to find.
Autospring 2" going on this week as well any issues I should watch out for?
Thanks for any input....
1. Silverstars for the H13 bulb are not out. NHTSA wrote the spec for the bulb not have any coating. Sylvania is lobbying to get the spec changed.
2. You can get the 4WD lower valence and mount them where the tow hooks would be.
3. Don't know about sub boxes but if you search this forum, and the multimedia forum, I'm sure you will find one. Might check the supercrew forum also.
4. Autospring issues. Upper control arm hitting the springs. Some folks have taken them off due to this. I went the opposite direction and put on drop shackles.
Originally Posted by kd4crs
...I went the opposite direction and put on drop shackles.
I got an MTX under the seat box, but it was for a "12. I love mine, it fit nicely, but you might have to look into it to see if they make them for a 10". You can get it with a sub, or without and use your own.
