Have you had ford to replaced the driveshaft due to shudder?
Old Apr 17, 2006 | 04:54 PM
YOMAN's Avatar
After replaced clutch pack, greased it etc and finally They decided to replace the driveshaft but they need special order for new one to come in to replace it.
I will bring it in Ford shop this wednesday and am NERVOUS about this cuz i am afraid it might be the worst than orignail driveshaft (more vibe/shudder).
They told me that driveshaft should be solve this problem as it just updated to specifity made driveshaft for it.
My question for you, MOST recenlty replaced the driveshaft, have you noticed shudder is gone ? or is it coming back after few weeks ?? feedback your experience please..
thanks!
YOMAN!
FX4 2004 Screw
Old Apr 17, 2006 | 08:03 PM
masshol's Avatar
By shudder do mean from a stop when you accelerate there is a clunking sound from the rear end?? You can feel it too right? That's the problem I've had since I got my 05. I've ignored it, hasn't got any worse or better...
Old Apr 18, 2006 | 12:37 AM
wamsleyb's Avatar
I got Ford to put the new aluminum DS in my screw because the pinion bearings kept getting roasted after 50 miles on a rear axle rebuild. The stupid axle would howl like a banshee between 68-72. Sine the DS replacement I got over 1,000 miles on the rebuild and it seems to be doing better. So it may help with the shudder if it is causing the rear end to act up, plus less rotating mass=better mileage.
Old Apr 18, 2006 | 01:29 AM
Lumadar's Avatar
How can you tell if you have the aluminum one or not?
Old Apr 18, 2006 | 01:34 AM
02fordhd's Avatar
Look For Rust. Also The Aluminum Will Be A Dull Silver Color.
Old Apr 18, 2006 | 01:36 AM
hmfic's Avatar
Ford replaced my driveshaft for the clunk at takeoff. I was kinda nervous also, but everything turned out great. No more clunk and never had a vibe before or after. Its been a few thousand miles since that clunk to, so it looks like it did the trick.
Old Apr 18, 2006 | 01:48 AM
Lumadar's Avatar
I *think* know what clunk you are talking about... can you describe the clunk you had?
And what do I tell the service advisor to make them change the driveshaft?
Old Apr 18, 2006 | 05:52 AM
memLT-1's Avatar
Try a magnate
Old Apr 18, 2006 | 08:20 AM
joenarb's Avatar
I've had mine replaced because of the clunk on take off. I've never had a shudder problem. but the new driveshaft fixed it. I watched them put it in and it is different then the factory one.
Old Apr 18, 2006 | 10:53 AM
YOMAN's Avatar
yeah I only felt shudder on take off (STRAIGHT) from dead stop or decrease speed (rare).
I really hope that driveshaft will help this like few of yours !
thank you!
YOMAN!
Old Apr 18, 2006 | 10:56 AM
YOMAN's Avatar
theres TSB for that...they greased slip yoke driveshaft and of course it lasted 2 weeks and i brought it in and they decided to replace the driveshaft as per TSB instruction included if grease didnt help. they have to follow the instruction like test drive and inspect on driveshaft .
Old Apr 18, 2006 | 11:15 AM
razorsharp1's Avatar
Yoman;
Mine was changed because they found the source of my shudder was a bad u-joint. They were going to change it, but it is on "national back order" so they just changed the entire d-shaft. Shudder gone, slip-yoke trouble gone, almost 5,000 miles now.
Dont worry too much about it, it was a good thing for my truck.
BJ
Old Apr 18, 2006 | 11:21 AM
anaheim's Avatar
thank you!
YOMAN!
Mine had the same thing, only on take off, when they rebuilt the rear end the shutter went away.
Old Apr 18, 2006 | 07:42 PM
hmfic's Avatar
Thats what they tried with mine. They greased up the yoke 2 times. Great for about 2 weeks then the clunk came back. Third time they changed the driveshaft and it worked. Thats what the TSB told them to do.
Old Apr 18, 2006 | 10:39 PM
I had the vibe and they changed the clutch packs and driveshaft and after that the vibe is still there. I'm beginning to think it's the torque converter or the tranny.
