Discount Tire Direct is Helpful Afterall!
Here is the video. The audio doesn't work at times so I just muted the rest, it was full of static and buzzing. I rub pretty bad but I still have the power I had, probably a few tenths slower in the 0-60 but I can't imagine I'm that much worse. I haven't taken it over 50mph and the humming doesn't bother me a bit. I hope cranking them up does not create a huge problem with my cv angles, I'm going to have to ride like that for a while. I think I'll do the 3" body as it looks a little stuffed even with the 6". I'll get pics in the morning. About the centercaps, they're growing on me but we'll see in the daylight.
I don't know how many more inches I have until the coilovers are maxxed out but my cv angles aren't the greatest as is, so I hope it will be ok. By the way, my front driveshaft is spinning again, the fuse has blown 5 times now, I am trying to catch it when it does as I have the fuses that light up when they blow, so the box at the passengers feet glows.
Now you can all sleep with closure ;P
rockin man- badasssss! can't wait to see some daylight shots- sweet!Justin
Ran into another problem, when I'm cranking the coilovers, it spins the actual threads with the collar, the collar is supposed to spin and not the threaded cylinder right? I cannot see how else it would elevate/increase in height. Any suggestions? I'm going to try it on the other coilover and see whats going on, maybe I need to loosen the allenhead screw more or just lubricate the hell out of it. I certainly can't park or make any sort of tight turns as is.
You should cut the lower blacvk plastic portion of the front bumper FOR SURE. Even people with 35s do that. Just carve it with a sharp pocket knife.. kind of like a 45 degree cut starting at the top of the lower piece, closest to the rear of the truck, and cut towards the front of the truck, and down.
Someone with a liftedt truck could take pics of their trimming no doubt. If you do it right it doesn't look bad at all, not even noticable and it should help a lot.
Good luck
Good luck
Good luck
Good luck
I can't figure out how to raise the coilovers, the collar is moving at the same time as the threads.
lol, alright. I took some for you two (my last thead followers ;P). Now kickass, you better come wheeling you god d*mn chicken.
Edit: I've posted them in the new thread titled, "Finally lifted on 37" Mud Grapplers." I hope you guys read that. (in a few minutes it will be posted, uploading the pics).
