fabtech hitting lower a-arm
Old Apr 5, 2006 | 02:11 PM
misato's Avatar
Exclamation fabtech hitting lower a-arm
anyone else notice it? the metal arm that comes off the spindle is ramming the lower a-arm at full stop left and right and its making a dent in the alum. a-arm. normal?
yeah I know, I'll get pics tonite...
Old Apr 5, 2006 | 03:07 PM
texxx150's Avatar
That's a very common problem, I think mainly with the guys (like myself) with some type of spacer installed. However, I remember there being several others that were completely stock experiencing the same thing. There is another thread on here somewhere with a bunch of pics... search away!
Old Apr 5, 2006 | 03:10 PM
-TXF150-'s Avatar
Do you mean that is is hitting the bump stop and wearing it down... If so, that is normal.. I try to not turn the wheel at full lock, unless it is completely necessary to do so...
Old Apr 5, 2006 | 05:58 PM
04procompLARIAT's Avatar
all it is, is a steering limiting feature. all the suspension kits have them. it limits your turning radius so your bigger tires wont rub on the frame when you make a full cranked turn.
Old Apr 5, 2006 | 10:11 PM
Ayresusn's Avatar
Yeah i have the same problem, the stops on the steering nuckles are hitting the lower control arm, but not in the factory spots.
Old Apr 5, 2006 | 10:42 PM
bushtree's Avatar
yep its normal. that is how the kit was designed to work..
