Awful starter grind!
Old Mar 27, 2006 | 02:03 PM
nitzer280's Avatar
My rig - 2004 4x4 XLT Screw.
You know the sound a starter makes on a vehicle if you try to start it when it's already running? My truck has done that twice in a month - but it makes the noise when the truck ISN'T already running.
Anyone else?
Old Mar 27, 2006 | 02:08 PM
roushlimited's Avatar
Anyone else?
Mine did that a couple times too and I found that it was my ignitions switch was sticking. I just sprayed a little wd-40 in it and so far so good.
Old Mar 27, 2006 | 02:13 PM
nitzer280's Avatar
Alright, thanks for the info! So, help out an I/T geek out - where would the ignition switch be?
Old Mar 27, 2006 | 02:29 PM
That place where you put the key....LOL .....
When mine was acting up when I turned the key it would stick forward a little bit instead of dropping back into place causing the starter to grind. Good luck
