I whine alot but I can't keep my foot out of it!
Old Mar 24, 2006 | 10:06 PM
flanaganman's Avatar
Originally Posted by 05RoushMarkLT
My last two tanks have been 12.5 mpg, and I have several of these whinning episodes during every tank. I used to get around 14mpg in Vegas driving, so it isn't too bad. I'm still in my break in period though, eventually I'll get a tank without several high RPM runs.
got to luv that sound ive had my roush since last summer and i still have high rpm runs every time i drive always someone going to slow someone to pass
https://www.f150online.com/galleries...w.cfm?num=9331
Old Mar 24, 2006 | 10:11 PM
05RoushMarkLT's Avatar
Originally Posted by Beefullo
I am not trying to sound rude here but (I realize the EDGE might not be the most accurate timing device) my 0-60 is under seven seconds and I don't exactly have a power adder as you can see. Could your extra weight (scab vs. screw) really be slowing you down that much? I suppose excess wheel spin could be the culprit.
Also, not to hijack your thread or anything but I was just looking at your cardomain site and I really love your tailgate. I have a few questions about it:
- How many parts are involved and how much did the entire swap cost?
- Are those lights or just reflectors on the tailgate?
- Could the Lincon emblem be removed with a heatgun or is it bolted on? Also is it endented into the tailgate similar to where the Ford emblem is on our tailgates?
If it isn't too ridiculously expensive I think that would make a huge aesthetic difference to our trucks. I would preferably want no emblem whatsoever on the back, if there is an indention I would look in to getting shaved.
Whipples test vehicle, a supercab 2wd got 5.8 0-60. Like I said in my original post, I really don't know how to launch a vehicle from a start, and the tires have a hard time not spinning below 20mph. Coming home tonight I was cruising about 35 and decided to play with a suburban in front of me that was dodging in and out of traffic, I had an opening with him in front of me, and the tail end fishtailed while I changed lanes. The new power is sick! I'm sure I'd be in the 6 second range with my added weight (supercrew, 4X4, tonneau, 22" wheels, etc.). I don't think watching a video timeline, or reading an edge is a good way to determine what the truck really brings to the table. The track is the only way to really tell.
As for the tailgate, I can't recall how much every item was because I bought so many of them together. The parts include the tailgate panel, two reflectors (not lights) and the tailgate handle. The panel has a recession for the lincoln emblem, so if you removed the emblem, you would still have the recession.
Old Mar 24, 2006 | 10:18 PM
Originally Posted by KiCk *** FX4
when are you getting your flares and mirors painted?
I might not get the painting done until May. I haven't gotten my fender flares in yet, and I have to leave on April 3rd for 4 weeks of work. I get back home on the 1st of May. I will probably focus next week on getting the new tune to remove the speed limiter, and getting a custom driveshaft with new u-joints and end loops installed.
Old Mar 24, 2006 | 10:24 PM
Josiah's Avatar
Hats off to you, what a sick truck. My truck is on blocks, you're teasing me. I am about half done with my truck, a little more cutting and reassembling. I should upload the pictures. In fact, I will check my thread soon. Once again, great truck, great sound, great video. Try not to WOT it off the takeoff and lets see what she runs.
Old Mar 24, 2006 | 11:03 PM
gmanjerseyfx4's Avatar
Thats hott as hell....i need to get a video like that!!
Old Mar 25, 2006 | 12:30 AM
rafa26's Avatar
My truck has 24" wheels which spin less and my 0-60mph is 5.85s.
Old Mar 25, 2006 | 12:54 AM
beep beep K alert (COBRA BRAND)
once you get your toneau, i would put 200-300 pounds of sand bags or something, up against the tailgate to weigh the back end down, Or just keep your tank really full.
Do you know what gear ratio you have, and if you have an open diff? because i have a 3.55 open and i can power brake it full brake full gas, and spin only a little off the line.... And i understand you have more torque, but still that much spinning is redicolous
Pretty loud whine. Not my cup of tea, but it sounds good
-Patrick
Old Mar 25, 2006 | 12:55 AM
rafa26's Avatar
-Patrick
4.56 differencial limited slip.
Old Mar 25, 2006 | 12:42 PM
Patman, I've got 3.73's. I'm sure if I didn't mash on the gas from a start it wouldn't spin as bad. I don't plan on doing any power braking unless I plan to play a little more with some burnouts. I had a fresh full tank on that video, and I only plan to throw a bunch of sand bags in the back of the truck around November when the roads turn to ice.
Thanks for all the compliments!
Old Mar 25, 2006 | 02:32 PM
Matt 05'FX4's Avatar
Your S/C definitelly has a different pitch than mine, it is cool how they all have their specific sound. I ran your vid right even with mine and it seems my truck begins to pull ahed up top by a little. That is cool having them both going, it sounds just like a race! Send me the vid and I'll dub them together! Yours starts right as you hit the play button so I play mine and the intro completes and as soon as I hear the engine I hit the play button on yours. Try it!
Old Mar 25, 2006 | 02:50 PM
Matt, that is pretty slick.
I think I see why you would pull ahead. I shift around 4900 RPM and it looks like yours shifts around 5100 RPM. You are getting more out of the lower gears. I really think Ford Racing had a lot of influence on whipples tune, and geared it way down. It looks like your tune helped you out quite a bit. I'll send you the video later on today, I gotta take the kid out to some kiddy stuff now.
Old Mar 25, 2006 | 09:13 PM
rambunctious's Avatar
Fella's
I just drove a stage III Roush. 445 Hp. ....... intercooled !!!
Job 1 hasn't hit yet, this is a custom ordered truck.
more to come, need clearance from Roush before I say more as this is a work related project, but couldn't resist the tease.
talk about throttle response !!!!!!
Ramb
Old Mar 26, 2006 | 10:28 PM
Originally Posted by rambunctious
Fella's
Ramb
BAH!!!! BASTARD!!!!! Please oh PLEASE tell me when that intercooler will be available. Put my name on one because it is as good as sold!
And I dubbed the 2 vids together the best I could, I couldn't figure out how to split screen that thing, only to blur the 2 together diagonally. Here is the link, and set size to ORIGINAL.........You can see it really good above 40, and at 45 we are dead even, and when I am at 90, you are at 80. But I know many things influence this.....it was probably a hotter day when you did your runs or something.
Old Mar 27, 2006 | 05:26 PM
mlawdawg's Avatar
My G tech said my Roush gave me a 6.9 today with a 15.2 quarter mile. It's shifting way early at 4900 with teh Roush tune, and I eased up a bit in the end as I saw a car a half mile ahead that gave me pause. Can't wait for teh 4.56 gears, dynomax and custom tune. And no, it's no a strip verified time for those who want to point such things out. It's and FYI.
Old Mar 27, 2006 | 05:30 PM
rafa26's Avatar
With 4.56 gears and Dynatech, you will drop at least 1 second on both times. Trust me, I use 4.56 gears .
