Who's got traction bars?
Originally Posted by hwm3
Look at the link in the second post. Those say they work on 97-03 trucks and bolt over the leaf springs. The leaves on the 04+ trucks are wider, which means the u-bolts used to attach those traction bars won't fit over the leaves.
My $ 0.02.
If you have lowered, you should take your truck to a drive line shop to have the pinion gear / trans realigned. I payed $ 80, and it solved the problem.
I later added much more hp, and had to cure the wheel hop again, but with the Lakewoods that hwm3 shows. They bolt on in an hour and work fine.... I sparyed black on the yellow snubbers though.
If your axle is on top of the springs, muscle car type traction bars, which do not need as much height / space , no axle to go around now, should fit. The spring width is the concern.
I suggest Summit for the more generic parts. You can call and talk to customer service, and they will usually have or find the info you need, like U bolt width.
Originally Posted by tschaid
the mount kit for the Pro Comp Transaction Bars comes with a bottom plate. Yes, your U-Bolts go through the new bottom plate. The width of the leaf spring; however, has nothing to do with this. If anything is a concern, it is the length of the U-Bolts. I believe the stock U-Bolts are long enough to make this work. I have a Pro Comp Lift installed so didn't need to worry about the length of the U-Bolts.
These are the bars I'm referring to, not the ProComp bars.
