Aftermarket Satellite???
Originally Posted by jmpancoast
This is a Kenwood Sirius HU I hooked-up a couple weeks ago. It is PIEed directly to my Audiophile HU and sounds great!
My truck is an XL and does have the cupholder under the radio. My cupholder is located on the hump.
This is the correct PIE adapter for direct wire hook-ups on our trucks:
http://www.crutchfield.com/S-9ZYrE6w...sion+interface
There are are cheaper places to buy them on the net. I have seen them for about $86.00 several places.
I put an XM Roady in my dads 05 Lariat. I wound up mounting it in the overhead bin (he listens to channel 10 95% of the time so changing the channels wasnt a real issue). The XM Roady has a built in FM modulator and we just used that. It sounds just fine on a factory system but may want to upgrade to a direct connect if you are very picky (like I would be), but my dad is perfectly happy with it.
I am expecting my truck to be delivered within the next week. Here is what I bought to mount a MySkyFi.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5872386026
Don't use an FM modulator, they are junk. You will be amazed with the sound difference by using a PIE!
This is a good supplier:
http://www.discountcarstereo.com/detail.aspx?ID=813
I mounted mine to the area where my cig lighter was. The antennea is mounted on my roof next to the drivers side A pillar. Just ran the cabling under the dash and up under the weather stripping to the roof.
