Leveling Kit Eats Ball joint
Old Mar 20, 2006 | 10:14 PM
takotruckin's Avatar
Exclamation Leveling Kit Eats Ball joint
ive got an 04 fx4 with a 2 1/2" autospring, i just noticed recently that the upper ball joint boots are MANGLED. i fear the ball joints are not far behind.
so, is mine a fluke? or do they all do this? is it just the 2 1/2" or do the 2" do it as well? im not prepared to give up my leveling kit. im currently considering/designing a custom upper a-arm, using either a heim joint or uniball to cure the problem.
Old Mar 20, 2006 | 10:28 PM
boobies78133's Avatar
i ruptured the seal on my passenger side ball joint during installation of my leveling kit, but i haven't noticed any additional tearing or unusual wear of the boot. i plan on replacing the ball joint this summer before it becomes an issue and starts effecting my alignment and eating tires.
Old Mar 20, 2006 | 11:23 PM
tardman91's Avatar
That's no surprise. Adding a leveling kit throws off the suspension angles and that will surely eat your ball joints. Especially if you drive off road or on rough pavement a lot. And if the F150 is anything like the Ranger, those ball joints will cost an arm and a leg to get installed.
Has anybody actually had to replace their ball joints on thier 04+ F150 yet?
Old Mar 20, 2006 | 11:26 PM
i think i remember hearing they come with the a arm, which means big money. im not prepared to give up my leveled truck, i am ready to fab whatever it takes, might even go long travel.(i spend my weekends building a baja bug, i have suspension/fab experience).
Old Mar 20, 2006 | 11:28 PM
-TXF150-'s Avatar
Here is your solution....
Old Mar 20, 2006 | 11:35 PM
thats exactly what i had planned, only to build my own. could also engineer them to allow more travel
Old Mar 20, 2006 | 11:48 PM
-TXF150-'s Avatar
You are going to drive your truck with a "HOMEMADE" upper control arm???
Old Mar 20, 2006 | 11:54 PM
dirk upson's Avatar
should be interesting to see if there are any trucks developing problems with there leveling kits.there should be some trucks with enough miles on to see how durable the ball joints are.
Old Mar 20, 2006 | 11:56 PM
BalogUK's Avatar
verrry interesting- will be checking mine when i get in the truck to go to school in the am (2.5" as)- hey tex, do you have a link or a cost for those upper arms?
Old Mar 20, 2006 | 11:59 PM
-TXF150-'s Avatar
I beleive the pair runs in the $500 to $600 range...
Here is the link.. http://www.chaosfab.com/fordf150.html
Old Mar 21, 2006 | 12:01 AM
dirk upson's Avatar
they are expensive because you have to buy king shocks or racerunner shocks.
Old Mar 21, 2006 | 12:09 AM
dirk upson's Avatar
i have the 2 1\2 inch kit .has anybody had any problems with the 2 inch kit?thinking about the bilstein leveling shock because you can adjust it from 0-2 inches.i just don't like the front sitting so low.
Old Mar 21, 2006 | 12:18 AM
Screw2004's Avatar
I have the 2in AutoSpring No clunking at all
Old Mar 21, 2006 | 12:24 AM
dirk upson's Avatar
how are the ball joints?
Old Mar 21, 2006 | 12:29 AM
i priced the upper control arms on fordparts.com it had them for around 70 each. the install would be about the same difficulty as installing the leveling kit.
i know the bilstein shocks that level the front end are new, but have any of you heard of problems with premature wear since they have the spring over extended putting most of the weight and work on the shock alone?
