Help! Truck died tonight
Wrench Light came on and shortly after the truck died. I could not get the truck to run so.. I pulled out my handy SCP tuner and pulled the following codes:
P2104
P2111
P2112
P2135
I disconnected the plug that goes into the throttle body and reconnected and it got the engine to run but Engine light was on.... Drove the rest of the 23miles back home and need advise?
I've seen many on here replace TB's. Unfortunatly it has 37,7XX on the Od, so I cant bring it in under warrenty.
Suggestions welcome.
Chris
P2104
P2111
P2112
P2135
Chris
all of those codes are pedal codes and Throttle act..., I would say it bad and need to be replaced....not a owner servicable part.....
http://www.iequus.com/obd_def.asp
Those are all ETC codes. More the likely, it needs a throttle position sensor and the latest available PCM calibration.
