Rear end problem...
Old Mar 11, 2006 | 02:53 PM
jope's Avatar
Rear end problem...
2004 SCREW 4x4 28k
I took my truck in for a rear end shudder, they said they'd order some grease and put it on next week.
Today I took my truck to a parking lot and turned in circles both right and left, when I was done there were two very well defined rubber circles in the parking lot. I was going at idle speed. I see this as the rear diff. not doing it's job. Any suggestions or other ideas?
Old Mar 11, 2006 | 03:36 PM
Statik's Avatar
my rear end shutter was the emergency brake hangin up. TWICE
Old Mar 11, 2006 | 03:49 PM
KSpencer's Avatar
If you have an open rear end, then I am not sure what the problem is, could be e-brake. If you have a limited slip rear end, then the most common problem is the amount of friction modifier that was added to the rear grease. The clutch packs on these LS rears are fairly sensitive to the condition of the grease. If the clutches cannot slip, then the inner and outer wheels do not have the ability to turn at different speeds when cornering causing binding and wheel hop in turns. Good luck.
Old Mar 11, 2006 | 03:54 PM
Marc Carpenter's Avatar
Originally Posted by jope
2004 SCREW 4x4 28k
And I am willing to bet that after you had that fun in the parking lot that the rear end did not shudder for a while.
Old Mar 11, 2006 | 03:59 PM
Statik's Avatar
had cluch packs replaced along with greese . it did it after that
Old Mar 11, 2006 | 04:32 PM
jope's Avatar
Your right!
Thanks a ton for the information guys!
