Wiring question for an 04 F150....
Old Mar 9, 2006 | 10:18 AM
yankeesfan81's Avatar
Hello, I was just wondering where everyone else tapped their remote wire for an amp to? I had it spliced into the power wire for the radio before but I didnt like it because I couldnt listen to the radio with the truck off because I could dain the battery. Basically I want it so that the amp turns on when the key is on ONLY.. Thanks
Matt
Old Mar 9, 2006 | 10:29 AM
FX4 Matt's Avatar
Registered User
If you are useing the Stock system, Go to the Fusebox use the radio fuse,
Old Mar 9, 2006 | 09:11 PM
no I am using aftermarket deck now..Pioneer..
Old Mar 9, 2006 | 09:34 PM
powerage's Avatar
Tap it in the steering column or the fuse box on an ignition switched wire. Or wire a switch onto theb blue switched wire on your deck. Then you could shut the amp off whenever you want.
Old Mar 9, 2006 | 09:45 PM
FX4 Matt's Avatar
Registered User
Well the new wiring harness should have a blue wire run it to your amp, the amp will come on when the unit comes on
Old Mar 9, 2006 | 10:06 PM
Thanks guys.. I have another questions now.. I have the Pioneer 6800 deck and I have a 4 channel amp that I am going to use to power my components in the front and my rears in the back doors.. My problem is that the deck only has 1 pair of outputs.. and I need to use 2 pairs of outputs for my 4 channel amp.. Could I simply just use a splitter to split the 2 outputs into 4?? Or could that cause a bad signal? Thanks guys I really appreicate this..
Matt
I have also thought about putting a switch in but not really sure if I want too.. I might just do that though... I was thinking about mounting it in the coin holder. Just drill a hole through the coin holder ...
