Wrong gears!!!!!!!
Old Mar 8, 2006 | 09:03 PM
ColoBulldog's Avatar
Wrong gears!!!!!!!
When I picked out my truck, I CAREFULLY searched through local dealer inventories online and picked out my XLT with exactly the options / equipment I wanted. I called the dealership, told them to get it ready and went and picked it up.
After many $$$ worth of mods, I discovered that I had overlooked the axle ratios in my quest for perfect ride. This truck has 3.55's!!! Not exactly what I'd call a performance ratio.
Here's the question - what's it going to take to replace them with 4.10's or something fun like that? Since it's a 4x4 I know there are two sets of gears to deal with. I'm pretty handy, but a mod like this is more than I want to tackle. Any idea of what it's going to cost me?
Thanks, folks!
BTW - I finally got around to posting a little gallery, so if anyone is interested in looking at my truck, help yourself!
Old Mar 8, 2006 | 09:04 PM
ThumperMX113's Avatar
I'd say around $1500.
Old Mar 8, 2006 | 09:09 PM
I'm going to have to bite the bullit and do it. the 3.55's just don't have enough pull for my tastes. Thanks for the info.
Old Mar 8, 2006 | 09:19 PM
Do you plan on adding any bigger tires?
Josiah's Avatar
I've heard of them being as low as $1100 installed. There are Ring & Pinion assembly kits you can buy. If you don't use 4wd you can get it for a little less than half that price.
Old Mar 8, 2006 | 10:12 PM
I do want to go bigger on tires, but not a lot - maybe 33's. I removed the factory lift blocks in the rear to level it, so I can't go to big.
I'll wait for all the guff over lowering a 4x4. I like it that way. I do need the 4x4 here in Colorado. It's snowing now!
Old Mar 8, 2006 | 11:05 PM
KiCk aSs FX4's Avatar
i want to gets some gears as well. especially since I have bigger tires. the 4x4 gears are expensive. The labor is most of it too. it pisses me off too because I saw them put some gears in a truck on i think Trucks! on SpikeTV and it didnt look that hard but when youre dealing with the differentials Id rather pay a professional to do it.
Old Mar 8, 2006 | 11:27 PM
ninemmbill's Avatar
I just replaced my 3.55 setup with 4.10. Here in Las Vegas it ran me $1050 for parts and labor.
Between the gear swap and the Edge programmer, I now love the way the truck runs.
Old Mar 9, 2006 | 01:01 PM
ChrisAdams's Avatar
Can't tell from your profile, is your truck two or four wheel drive? 1050 is either about right or way high depending.
Chris
Old Mar 9, 2006 | 03:32 PM
ninemmbill's Avatar
Mine is a 4x4
Old Mar 9, 2006 | 08:14 PM
03SNKE's Avatar
Doing a gear swap is pretty touchy, I believe some special tools are needed to set backlash properly. If you want to do it yourself thats awesome- but I would do some research on what exactly is involved, otherwise you might end up with a whine/clunk or who knows what else.
Steve
