1st oil change
Originally Posted by 05FONEFITY
has anyone found out how hard it is to change your oil filter the first time? and if so is the second oil change any easier as far as replacing the oil filter?
Yes, the second one will be easier...unless you have the same machine put on your next oil filter...I just got my truck less than a month ago so mine will be just as hard...I'm letting the dealer do the first one for me, then I'll do the rest.
R/
Craig
R/
Craig
yeah I had a hell of a time trying to get my first filter off...there was nothing left of the filter when I was done with it...I can't believe they put those things on that tight from the factory
It's up to you, how hard you make it.
they are handtight
