Which Code Alarm
Which Code Alarm
Which Alarm/starter should I go with
CA630 Vs. CA550
Do I really need an alarm in the truck? Doesn't the chip in the key prevent theft?
Also, what else does the 630 offer me?
CA630 Vs. CA550
I got the remote start because it gets damn cold sometimes and I like to have a nice warm truck to go to. The remote start is a lot better than going with leaving the key in the ignition without being in it. I know you didn't list the 2-way CA-670, but that was the system I went with. I really like it...I can start the truck and get a confirmation that it actually started. The alarm part is nice, but it won't keep someone from smashing the window and taking my stuff.
The PATS bypass I went with says it will maintain the factory PATS system functionality, so I do not *think* having it is an issue or increases the chance of a theft. Here are the specs for it and they work with the Code Alarm systems.
Hope it helps.
Dave
Hope it helps.
Dave
I got the code alarm 670 as well. I had some issues with it in the beginning, but i took it back and they straightened it out. Make sure that whoever installs it, calls the Manufacturer to find out how to wire it up to your truck. There is a right way and a wrong way to do it on our trucks. The wrong way the truck will beeb about 5 times every so often and eventually set off the alarm. It happened to mine, at 5:00 am!!!
I like the features alot, the 2- way remote is killer! I can also check the temp inside the truck on the remote! Start confirmation is worth it's weight in gold too.
