Front Suspension Squeaking....Any Ideas??????
Old Feb 21, 2006 | 10:25 AM
CaseyKM28's Avatar
It seems like everytime I go over a bump, I get a squeaky noise coming from the front end and its annoying as hell. I am thinking its coming from the poly urethane bushings. Or its coming from where the upper part of the spring contacts the rubber piece. Im not sure where to start or exactly what to do.
Any ideas?
Old Feb 21, 2006 | 10:31 AM
MHP's Avatar
MHP
My truck was doing the same thing, drove me crazy. I found that the 3 nuts on the top of the shock housing were loose on both sides. Probably from my Daystar install. I tightened them up and no more squeek, that is where I would start.
Old Feb 21, 2006 | 10:55 AM
mountaineer02v8's Avatar
if the above statement does not work. I'd buy a grease gun and grease up anything that moves in the suspension. I have done that with mine in the past, and its been quite since the day I greased everything up.
Old Feb 21, 2006 | 11:12 AM
Rochester's Avatar
Same with my skyjacker spacer. The dealer was the one who installed it. 2 days later it started squeaking. I took it back and they tightened the bolts. No more noise. Good Luck.
Old Feb 22, 2006 | 09:25 AM
mkinttrim's Avatar
Did you put a light coat of grease on your ploy bushings? If not thats where the squeek is coming from, put poly bushings on my sway bar and did the same thing, had to take them out on grease them and put them back on.
Old Feb 22, 2006 | 09:34 AM
HCFR-Halligan's Avatar
Hey Casey how do you like that skyjacker lift? does it seem to keep the angles whithin spec? Lokks real good btw.
Old Feb 22, 2006 | 10:56 AM
nelson1each's Avatar
had the same squeak. tightened up the three bolts on the strut housing. hasnt made a noise since.
